Results 1 to 6 of 6
This is a discussion on Banging noise from ABS/calipers when hard braking? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When i do a quick dead stop(i would push the brake pedal all the way in to lock up the ...
    Dec 2004
    Los Angeles
    When i do a quick dead stop(i would push the brake pedal all the way in to lock up the brakes) in my 05wrx around 30/40 mpr, either the front or rear brake would make a loud banging sound, i can feel it on the brake pedal, it feels like the ABS kicked in for just a half second instead of pulsing, but it makes a loud banging sound.
    Anyone has experienced this? Thanks.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Greetings,
    I have moved your thread to the appropriate forum. I do not have an answer for your issue - someone in this forum may be able to help you.
    Welcome to the club!
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Moderator
    Jul 2003
    Maryland
    Subaru has a TSB I believe for the ABS computer. Have you had yours done?
    The wrx's do have alot of ABS complainants kicking on/off at odd times.
    Nov 2005
    Central Florida
    did you break the brakes in ? or do u have any brake mods ?
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Dec 2004
    Los Angeles
    Bang Noise from hard braking
    The rotors are stoptech with axixs pads, braided lines and motul fluid.
    Quote Originally Posted by rr1911 View Post
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    Check all your brake mounting brackets, and caliper slide pins, and check to see about the service bulletin.
