Stored STi while in Iraq and Brake Pads Rub While Driving...WHY??
Results 1 to 8 of 8
This is a discussion on Stored STi while in Iraq and Brake Pads Rub While Driving...WHY?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello all, Well I just got back from 7 months in Iraq, and took all the precautions with storing my ...
    Registered User LukeWRX's Avatar
    Jan 2003
    Stafford, VA
    Hello all,
    Well I just got back from 7 months in Iraq, and took all the precautions with storing my 04 STi: Fresh Fuel with Stabalizer, Fresh Synth Oil, Air'd up my old stock tires to prevent flat spots, sprayed WD-40 on undercarage, eng compartment, and brakes to prevent rusting, washed and waxed, hell I even stored the car in a Car Capsule(see bubble)
    When I took the car out of storage the other week it was just like I left it. I "un-stored" the car and went to drive it, and it sounded like the brake pads were rubbing the rotors as I drove. I have driven it about 10 slow miles to identify the problem and I believe it is isolated to the rear brake pads rubbing the rotors when I drive. At speed you can slightly smell the pads rubbing as if someone left the E-brake on.
    Note: when the car was stored I left it in 1st gear, and had the emergency brake on. I also checked the "disengaged" gap between the pads and rotors with a .010 feeler gauge and there is NO GAP. I cycle the brake pedal and the pads hardly move.
    Can anyone help
    Thanks Luke
    2004 STi
    Blitz DTT-DCII
    COBB Stage 2
    Invidia Catless DP
    HKS Hiper Cat-back
    Greddy: EGT, Boost, Oil Press Gauges
    Perrin Oil Catch Can
    Jan 2005
    Canada B.C.
    I would check/clean/grease the sliding pin/bolt that the calipers move on, it's probly rusted from lack of movement/use.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Registered User Scuba Steve's Avatar
    Sep 2003
    Minnesota
    I believe the ebrake on a STi uses a different system, not the typical cable to rear caliper system you find on most cars. You probably have to take the caliper off to inspect the ebrake mechanism itself. I would check to make sure all internals parts can move freely and not frozen.
    Here's a couple pics found on scoobymods.
    http://www.scoobymods.com/forums/showthread.php?t=4247
    good luck!
    Dave (aka Scuba Steve)
  5. #4
    Jan 2003
    Stafford, VA
    Thanks for the replies.
    I am upgrading to DBA rotors and Porterfield pads this weekend so I will inspect the calipers and drain and service the brake fluid too.
    Thanks for the help
    2004 STi
    Blitz DTT-DCII
    COBB Stage 2
    Invidia Catless DP
    HKS Hiper Cat-back
  6. #5
    Administrator ...De Rerum Natura TheJ's Avatar
    Bro do you even live in the Dirty South
    Thumbs up
    BTW,
    Thanks for serving your country, Luke.
    -The J 𒂼𒄄
    "Driving most supercars is like trying to manhandle a cow up a back staircase. . . This is like smearing honey into Keira Knightly" -JC
  7. #6
    Registered User power091999's Avatar
    Jul 2003
    Definatly something with the e-brake. Good luck, and let us know what it actually was after you upgrade your rotors.
    BTW:
    Thank you so much!
  8. #7
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Leaving the e brake on for that length of time might have locked it up. No big deal and since the rotors are coming off anyway you will find out your problem.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
  9. #8
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Quote Originally Posted by PolarisSnT View Post
    If the rotors will come off with the ebrake "engaged."
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
