06 wrx, CEL and will not rev after converting back to stock.
Results 1 to 6 of 6
This is a discussion on 06 wrx, CEL and will not rev after converting back to stock. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok, I converted my car back to stock from a vf39 conversion. I put everything back exactly as it should ...
    Registered User StupidMan's Avatar
    Nov 2005
    VA baby
    Ok,
    I converted my car back to stock from a vf39 conversion. I put everything back exactly as it should be, checked and re-checked connections, but I am getting a CEL and my car will not rev at all. If I put the gas to the floor it will slowly rev to about 2k and not go any further.
    The only thing I can think of is an electrical problem, but I only had to mess with the o2 sensor to convert back.
    Also the CEL will not go away with a battery reset, so I am assuming its electrical.
    It won't rev at all, so I cannot take it to autozone to get the CEL checked.
    Any suggestions?
    stupidman has spoken
    Oct 2004
    Westchester Cnty, NY
    Really bad leak? Did you disconnect the Test cables?
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    Nov 2005
    VA baby
    Quote Originally Posted by D0WNxSH1FT View Post
    Yeah, I disconnected the test cables. I will quadruple check the connections and report back.
    Thanks
    Nov 2005
    VA baby
    checked all connections in the exhaust and turbo. Checked all of the intercooler connections, vacuum lines, and intake.
    Do you think I maybe cracked my intake tube? It almost does seem like a leak after the map sensor or something. I noticed the intake tube looked streched from the vf39.
    Could it be the o2 sensor in the DP? Like maybe it was damaged during install/re-install?
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    Kinda off topic but why are you going back to stock?
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
    Oct 2004
    Its possible, im not really sure. Check your Inlet Tube under the Intercooler, is it cracked?
