Stock bushings or aftermarket?
This is a discussion on Swaybar Grease? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Could I get some at Pepboys? What type/brand should I use?...
1990 Alfa Romeo Spider Veloce
1993 Honda CBR600F2
2002 WRX SportWagon *sold*
aftermarket.
I have Cusco swaybars and Whiteline rear swaybar mount.
aftermarket tends to use a silicone type grease.
use some plumber's grease, other greases tend to break down over time from weathering.....plumber's grease does not.
BLUE RIDGE PEARL GC8 with some stuff.
WWW.HAGGARDFORUMS.COM
http://www.imagestation.com/picture/...a/fdb29c40.jpg
Don't know about plumbers grease. Silicone is what you need for the eurathane. It can be hard to find. It's often sold in small tubes as "tune-up grease" - 'cause you use it on spark plug boots.
1993 Honda CBR600F2
Cusco utilizes rubber like oe, but silicone is what you want- I've used sil-glyde, napa part # 765-1351. For urethane bushings I use Reese teflon hitch ball lube-it utilizes white teflon, very slick and it lasts.Originally posted by GV27
Big Sky
I'm familiar with a couple other options:
1. Teflon tape - works quite well and is the least messy, but does wear out (probably as often as the average grease.)
2. My favorite option is Anti-Seize. It stays put better than just about anything out there, and I've experienced nary a squeek on the last 3 cars I've owned.
--Steve
There was a TSB from Audi afew years ago regarding sway bar squeak. Anti-seize Compound was the fix for it.
For the stock ones I always use wheel bearing grease to get rid of squeaks. None ever came back to the dealership after I lubed them, so It would seem like that would work just fine.
Joe
merlin916@aol.com
"Damn.... this car is wicked fast..." ~ My roomate, owner of a supercharged/intercooled 97 Trans AM
Mods |
www.automotion.com sell a kikass grease for use with urethane bushings. Works great, ,soo sticky & gooey
j.p.
silver '03 wagon
