Results 1 to 9 of 9
This is a discussion on Blown Head Gasket??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So My cars been "using" anti-freeze pretty quick and after driving around when i turn the car off there's a ...
    Jul 2006
    Pueblo, Colorado
    Post Blown Head Gasket???
    So My cars been "using" anti-freeze pretty quick and after driving around when i turn the car off there's a "sweet" smell to it. I was wondering if this could be a blown head gasket. I've put on an aftermarket downpipe and had a boost spike and fuel cut right after installing it and a few days later began to notice this smell. The car doesnt have a problem with overheating or anything but I was wondering if anybody knew if the dealership would cover this under the warranty and if I should go with a 3 layer meatal gasket when replacing? Please help
    Registered User ScoobVee's Avatar
    Mar 2004
    Have you ever looked under the car to see if its leaking coolant?
    I would look around for any signs of a leak first
    - Local Riceist
    Jul 2006
    Pueblo, Colorado
    Yes I have checked and no sign of any leaks
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    open the radiator cap and see if theres bubbles comin up when it runs. or if you smell antifeeze out the exhaust.
    07 white STi in CT
    Jul 2006
    Pueblo, Colorado
    the exhaust smells like it's running rich and the sweet smell is around the motor area of the car, sometimes i can smell it in the interior with the windows up
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Check the radiator seams.
    Mar 2004
    Or the pass. floor board for a nice little puddle lol
    - Local Riceist
    Moderator
    Jul 2003
    Maryland
    +2 on your floor board and raditor seams. Also check the hoses for the turbo resevior also. Check the turbo coolant lines as well.
    Registered User WagonGuy's Avatar
    Sep 2005
    Chicago
    Check the oil dipstick before first drive of the day to see if the oil level is correct and is not mixed with the coolant. If it's higher then normal then the coolant is leaking into the oil shield.
    Blobeye Syndicate #1337
    man vs technology blog
    MvT@YouTube
