Clicking sound from engine
Results 1 to 15 of 16
This is a discussion on Clicking sound from engine within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Sounds like the lifters but we just changed those With a brand new Cam belt tensioner ...its really loud, just ...
    Registered User SubbyPAT's Avatar
    ChicagoISH
    Red face Clicking sound from engine
    Sounds like the lifters but we just changed those With a brand new Cam belt tensioner ...its really loud, just changed the oil and drove it for 4-5 miles and still the same.
    Any suggestions?
    04 WRX
    clicking is loud during idle, and speeding up..coming from the engine.
    Aug 2006
    Lake Zurich, IL
    the boxer engine always ticks and is noisy. Mine does it to and I was always worried but then I read up on it and found out it is normal.
    Mar 2006
    LA area
    Mine has the clicking/ticking/whatever sound and did so from the day I drove it off the dealer's lot. It is normal. I've heard everything from valves, to fuel injectors, to the design of the engine. Whatever the reason, it's normal.
    ChicagoISH
    Quote Originally Posted by TheFNG View Post
    Wanna post a sound clip during start up (cold) and idle? That would help me alot!
    Registered User scotts05's Avatar
    Sep 2005
    Beavercreek, OH
    ya my engine ticks too and thought something was wrong with my motor. sometimes it does and sometimes it doesn't
    2005 Ubaru Impreza WRX Sedan Crystal Grey Metallic
    Mods: In my profile
    http://www.myspace.com/scottycruz
    ChicagoISH
    Anybody have sound clips?
    ChicagoISH
    and does it matter if im using 5w30 for oil? Should i switch to 10w?
    Registered User rattlesnake6298's Avatar
    Aug 2006
    I Love Wrx's
    Aug 2006
    Lake Zurich, IL
    Quote Originally Posted by SubbyPAT View Post
    use 5w30, especially if your are in IL I am here as well Northwest suburbs and 5w30 is what you need cause 10w30 is something you may use in a warmer climate if it is warm all the time. Cold temps here make 5 w30 the b est
    ChicagoISH
    I thought 10w30 is best for colder climates?
    Aug 2006
    Lake Zurich, IL
    no 10w30 is a thicker oil so it is better for hot climates.
    Mar 2006
    LA area
    The difference between 5W30 and 10W30 is only noticeable in sub freezing temperatures, and then really only during start up.
    I use 10W30 Mobil 1 in my car, and I live in southern CA. The owners manual doesn't recommend against it anyway, so I have no worries.
    I have no idea how to make and post a sound clip, or else I would probably do it.
    To add, the lower the number before the "W" the more suited it is for colder climates. The "W" is the winter viscosity. The lower the number, the easier it flows in really cold temperatures. Don't go with anything less than 5W unless you live in northern Alaska.
    ChicagoISH
    im just gonna go to a dealer today that has an 04 rex....im gonna start it up and compare
    ChicagoISH
    To add, the lower the number before the "W" the more suited it is for colder climates. The "W" is the winter viscosity. The lower the number, the easier it flows in really cold temperatures. Don't go with anything less than 5W unless you like in northern Alaska.
    Possibly do a short video of some sort?
    ChicagoISH
    Alright i also got some insite that it might be the oil retainers.....it would prob explalin the idle clicking and the clicks going away during higher rpm.
    and oil pressure regulator valve, oil pump, oil pump seals.
    what you think ?
