please help
Results 1 to 3 of 3
This is a discussion on please help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a quick question. Hopefully someone can help me out. I have recently installed a new clutch and am ...
    Registered User clbourq's Avatar
    Nov 2005
    Hilton Head Island, SC
    please help
    I have a quick question. Hopefully someone can help me out. I have recently installed a new clutch and am in the process of breaking it in. However, out of the blue, my car has started idleing really rough and sounds a lot different. It backfires very often and I cant quite figure out why. I am thinking it might be the O2 sensor? When we took the tranny off is it possible it could have gotten dirty? I am going to get the car scoped tommarow to check the check engine code. Any ideas would be very much so appreciated. I am running a catless 3" exhaust and had a previous check engine code of small leak in the emissions system. I am hoping that there is a new code being thrown so that I can get an idea of what else could possibly be wrong.
    Jul 2001
    Plains of Eastern Montana
    the cel code(s) would be the most telling on what's possibly going on
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    If it's running that ruff, give your ECU a reset and see if its still that way. If the sensor is bad it may take a bit for the car to go into limp mode and give you similar results. You should see a difference.
    Do you have engine management? A catless exhaust will net you a rich running car with backfires.
