Not reaching full boost
Results 1 to 9 of 9
This is a discussion on Not reaching full boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 03 WRX and I was running on .09 mpa's for a while... but now it wont reach ...
    Registered User team123luder's Avatar
    Aug 2006
    California
    I have a 03 WRX and I was running on .09 mpa's for a while... but now it wont reach full boost in 1st and 2nd gear......
    I'm using an HKS boost controller...
    could it be my turbo taking a crap on me?
    Proud owner of a 2003 scooby wagon
    And a 1991 Honda prelude!
    Moderator
    Jul 2003
    Maryland
    BC's do go bad. What other mods do you? Are you going WOT I assume? What kind of load on the motor? At what rpms were you going off of before? It isnt un common not to see full boost in the lower gears.
    Aug 2006
    California
    The car has an HKS 3" from turbo back....HKS highflow intake and HKS BOV...
    The car is pretty much stock after that. power wise. She used to reach full boost at 3k at WOT all the time.... I just recently started to notice she wouldn't reach the desired boost level anymore...
    The engine has 51k on it.
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    Check the BOV spring or operation. Could be bleeding pressure at lower engine loads.
    No personal experience on this but LOTS of Subie owners pooh-pooh aftermarket BOV's, BC's, and CAI's.
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    Most of the time you won't hit max boost in 1st, sometimes in 2nd. Are you hitting it in 3rd gear?
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    did you take the restrictor pill out of the wastegate line, from what I understand that needs to be removed to use a MBC
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Aug 2006
    California
    Yup im trying to reach full boost in 3rd gear.
    And I don't believe it's a manual boost controller.
    I heard something about the ECU cutting back boost at high rpm...... could this be the case?
    Apr 2006
    York, PA
    Quote Originally Posted by team123luder View Post
    then what is this?
    the ecu doesn't cut back on boost the turbo itself really cannot keep pushing air above about 6000 rpms due to its size
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Aug 2006
    California
    Isn't the HKS EVC an electronic boost controller?
    And you're probably correct.... meh. VF34 is looking a lot better. thanks guys... I love this site. I've been a huge Honda fanatic but coming here and not hearing all the BS you hear on those other sites is relief.. thanks a million.
