engine checkup
Results 1 to 7 of 7
This is a discussion on engine checkup within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i wanted to know what you guys that dont take your car to the dealer do for normal maintence. im ...
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    engine checkup
    i wanted to know what you guys that dont take your car to the dealer do for normal maintence. im not talkin about changin you oil or anything like that. but my car just turned over 97k. i know its alot but i wanna know what should i check or do. like a leakdown test, compression test, or anything like that.
    07 white STi in CT
    Jun 2006
    NW ct
    anyone?
    07 white STi in CT
    Moderator
    Jul 2003
    Maryland
    Look at your service manual and see what the nearest mileage consists of. Odds are it's plugs, rotation, inspection, and full fluid change. Do that basic stuff that is outlined in the manual. From there you can do farther tests if you want, but it's all peice of mind stuff at that point.
    Jun 2006
    NW ct
    thats what i thought. i just changed my fluids, rotated and balanced the tires, alignment and checked everything like that. i think im gonna do the peace of mind stuff anyways.
    how much is a compression tester and stuff like that. is it more feesable to just take it to the dealer or a shop?
    07 white STi in CT
    Moderator
    Jul 2003
    Maryland
    A compression test really isnt maitance unless you think something is broke. You can have a good shop do one, but unless you suspect something is wrong you are more then likely tossing money away. Even if one cyl. is down 15 from another are you going to want to fix it now or just drive it until it blows? If you just want to drive it till it blows then I wouldnt even bother because it will just worry you more.
    If you did all the maitance (wires, timing belt, acc. belts, fluids, rotation, etc) then the only other thing I'd do is replace the oil pump. Oil pumps seem to want to go around 70-110k miles in these cars. Whoever does your timing belt I'd ask them to do an oil pump also.
    Jun 2006
    NW ct
    sounds good, thanks. ill probally just keep drivin and puttin mods on until it blows or i finish another power and performance class at UTI and then rebuild
    07 white STi in CT
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    Quote Originally Posted by 302@12psi View Post
    +1 on the timing belt and oil pump. Timing belt if you don't want to replace your heads when rebuilding. Low tolerance valve to piston gaps = bent valves.
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
