Converting from a 700-R4 to a 4L60-E ?
Results 1 to 4 of 4
This is a discussion on Converting from a 700-R4 to a 4L60-E ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I mistakenly purchased a 4L60-E transmission out of a 1993 Chevy 2500. I have a 1992 GMC 2500 with a ...
    I mistakenly purchased a 4L60-E transmission out of a 1993 Chevy 2500. I have a 1992 GMC 2500 with a 700-R4 transmission. How hard would it be to convert my truck to use the electronic transmission?
    Thanks
    gary
    Jul 2005
    Northern Illinois
    Wow.
    You may want to try a different forum.
    Anyway, the electronic trans needs intructions from a control module in order to work.
    I looked into installing a L480e into a 700R4 car and it required a daughter board on the ecm in order to work.
    My two cents.
    WR
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Yeah this is a subaru board but since I just sold my 93 Chevy 4x4 I'll see what I can help.
    Fundamentaly the 700r4 and the 4l60e are the same tranny, but the 4l60e has electronics controlling kick down, valve body functions, line pressure, etc. I also believe the 93 is spedometer by wire while the 92 could be cable. Also the VSSB's are different. So to use the 4l60e to its potential might require lots of expense and labor. i.e. New ECM, wiring, VSSB, speedometer setup, etc. The 4l60e might however have provisions to run manually like a 700r4 and could be as easy as a bolt on.
    my .02
    re:
    thanks
