90 mph makes a quick noise like going over center lines!
Results 1 to 4 of 4
This is a discussion on 90 mph makes a quick noise like going over center lines! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; First thing when I get to about 90mph I hear this sound in the rear as if I'm going over ...
    Seattle
    First thing when I get to about 90mph I hear this sound in the rear as if I'm going over the line on the freeway but it stops once I either let go of the pedal or hit 95mph. What is it? I thought it was the exaust because of the certain vibrations but i figure it would happen if i hit the high rpm in the lower gears. Another problem is when i get to about 110mph it begins to jult as if it loses power? does it need an ecu?
    Registered User kiger0183's Avatar
    Oct 2005
    SLC, Ut
    first thoughts....You got funky tire tread on those back tires.
    Do you rotate your tires every oil change? I can almost guarantee that's the problem with your speed "noise" at certain mph's. Check out your tire tread on the back tires. Hope this helps. Good luck!
    Stage II and loving it!
    Nov 2005
    Central Florida
    my STi always makes weird noises @ 100mph and 4k on the revs... i think its normal
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Seattle
    i dont think so
    i dunno i highly doubt it because it feels like its the frame or something is rubbing but then again at those speeds you never know. i will check it out. thanks
