Please Help!!! CEL issue...
Results 1 to 8 of 8
This is a discussion on Please Help!!! CEL issue... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was merging into traffic yesterday and as I was accelerating in first gear I hit a pothole, I shifted ...
    Registered User Blue_Eyez_'s Avatar
    Mar 2006
    Birmingham, AL
    I was merging into traffic yesterday and as I was accelerating in first gear I hit a pothole, I shifted to second and noticed that my car had thrown a CEL. I was on my way home, so as soon as I pull in the driveway I pull out the AP to check and see whats going on. I follow the instructions for checking CEL's but the AP is not finding any. I go thru the routine a couple of times but still nothing. I go ahead and attemp to clear the cell (reset ecu) and it will not clear it. I then remove the battery cable and push the brake for a few seconds and still, when I repace the cable and turn the car on I get the damn CEL!!
    I am out of idea's...anyone know whats wrong with my car? Do I need to take it to the dealer??
    Any help is appreciated!
    HAWK-EYE ALLIANCE #44
    2006 SGM WRX
    Cobb Stage 2
    APS 3" Catted TBE
    H-Tech Springs
    Eibach 10mm Spacers
    Registered User Cuztom15's Avatar
    Apr 2004
    River City, NJ
    Like OMG, i know exactly whats wrong with you car with that information!!!!
    No seriously, take it to autozone or any such place and have them pull the code for free, or if you get your hands on an OBD-II scanner, you can do it yourself.
    Do that, list your mods, does the car feel different in any way, etc, then update us....dealer is always last option....
    Blobeye Syndicate #17
    Mar 2006
    Birmingham, AL
    Car runs great. Doesnt feel any different.
    Mods are in sig.
    Codes are:
    P2431
    Sec.Air Inj.System
    Airflow/Press.Sen
    CKT Rng/Perf.Bank1
    P2433
    Sec.Air Inj.System
    Airflow/Press.Sen
    CKT Hi Input Bank1
    Thanks for the help...
    2006 SGM WRX
    Cobb Stage 2
    APS 3" Catted TBE
    H-Tech Springs
    Eibach 10mm Spacers
    Apr 2004
    River City, NJ
    ok so the secondary air system is an emission related system that injects extra oxygen into the exhaust pipe to burn off any extra fuel. the system only activates on cold starts (when the coolant temperature is between 15 and 35 degrees Celsius). the system consists of a large air pump, one or two combi-valves and a solenoid if im not mistaken. The valves are controlled via vacuum lines that cause them to open and close.
    I suggest locating the vacuum lines and check them to make sure theyre not popped off, frayed, cut, etc. I dont really remember much else as to the cause. I havent had any problems with this stuff so i can not give you a location. Hopefully someone else can add to this.
    Just a side thought, check your boost solenoid, maf, all the like, etc.
    Mar 2006
    Birmingham, AL
    Thanks for the info!
    2006 SGM WRX
    Cobb Stage 2
    APS 3" Catted TBE
    H-Tech Springs
    Eibach 10mm Spacers
    Apr 2004
    River City, NJ
    also, if it wont reset, its a hard code, its more then likely electrical, i completely overlooked that. Check over all the electrical connections going to the air pump.
    Mar 2014
    Mn
    Having the same problem with my 06 wrx limited and I'm stage 2 too
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Saintwrx View Post
    So then follow said instructions above and get ahold of the factory service manual that has the diagnostic tree in it for the DTC's.
    2002 FORESTER S
    1998 FORESTER S
