Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on Brake System Warranty issues with aftermarket rotors within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I agree with tan. If you are using the same size rotors and calipers, I don't see how they can ...
    Registered User MadDog's Avatar
    May 2002
    Land of many cows
    I agree with tan. If you are using the same size rotors and calipers, I don't see how they can claim that the rotors caused a failure in the ABS system.
    If you went in there and asked them to replace the rotors, I could understand. But if the ABS system is faulty, what rotors you have on the car wouldn't really make a difference. Again, they have to prove that any aftermarket part was the cause of the failure.
    Sometimes it takes a call to SOA to straighten it out. Talk to the service manager, and if he can't help you, ask to get in touch with a SOA rep.
    Trunkmonkey Racing
    Team Monkey Wrench
  2. #17
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    In this case, I'd raise a fuss. Rotors are wear parts.
    misterx
  3. #18
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    something I'd check are the tire pressures, if under-inflated it gives the ABS speed sensors the impression of the wheels spinning slower, if each tire has way different the pressures, it would " Confuse" the ABS system.
    That's all I can think of for possible reasons.
  4. #19
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Originally posted by Jasno999
    They caleld back said it may be an ABS issue. But they said if it is linked to the rotors then warrany is void. If not they will fix it under warranty.
    That's totally fair and exactly in line with the law. If the problem is directly linked to the aftermarket part, then it is not covered under warranty. If not, it is.
    What was the final outcome?
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
