threw a code, and i have no idea why - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on threw a code, and i have no idea why within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; The cat being referred to in regards to the EGT sensor is you up pipe cat...not the down pipe cat. ...
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    The cat being referred to in regards to the EGT sensor is you up pipe cat...not the down pipe cat. If your UP cat desintigrates, believe me...you will soon care.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    ah
    i'm used to cars with one cat.. like.. this multi-cat thing.. is ****ing LAME.
    03 WRX - daily driver
    91 teg - needs a trans, the current one is soup.
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    100% its your EGT sensor. Get the resistor from radio shack for $1.99 and fix it Done deal.
    If it is in fact a cattet UP you should get it looked at. If it's an aftermarket most likely it is not catted. You should be able to see it from the engine compartment, just get a flash light and take a look on the left side of the engine at the bottom. If you see generic heat shielding on the pipe its most likely stock.
    Sry if I missed info somewhere in the thread.
  6. #19
    Registered User mangiardi83's Avatar
    Feb 2005
    howell MI
    hey im having the same issue, where does the resister go? what kind of resister? also i was told to get a spark plug fouler for the o2 sensor but im not sure which one front or back sensor? any body? can some onr help me out!
  7. #20
    2.2 kohm 1/2 watt, as previously listed, do you put it in line with the sensor so that the computer reads colder, or do you subsitute it for the sensor altogether?
  8. #21
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    Quote Originally Posted by function/form
    Substitute for sensor altogether. just unplug the EGT ( under/near the boost solenoid on the LH side by strut tower ) and stick one lead in each of the two female connector openings.
    If you ever were able to get the EGT to trip ( setpoint 1800 F ) your turbo and/or pistons are already toast...
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
  9. #22
    ?... most computers are set up so that one sensor can't kill much, it just gets ignored if all other data is condtradicting it... i dunno, i'll prob. swing by radio shack this week tho, and take care of the issue.. btw, when i sub the resistor in, is it gonna run a little rich all the time?
  10. #23
    Jul 2003
    PA
    No it will not make it run rich.
    BTW everyone...search is your friend. Here is the the resistor mod thread DIY..with pics.
    2.2K Ohm Resistor Mod
