Bad shifting - check engine light
Results 1 to 14 of 14
This is a discussion on Bad shifting - check engine light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My check engine light came on after a pretty bad shift. the book says its an emission problem but Im ...
    Sep 2006
    NJ
    Unhappy Bad shifting - check engine light
    My check engine light came on after a pretty bad shift. the book says its an emission problem but Im scared its the tranmission. Could something just have been knocked loose?
    Registered User Yossarian's Avatar
    Jan 2006
    Ohio
    Bad shift as in synchro grinding, or bad shift as in oops I thought that was 5th not 3rd 9000rpm shift?
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    Quote Originally Posted by Yossarian
    heh, I've done that before.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    what exactly was the code that was pulled?
    Sep 2006
    NJ
    I dont know the code nor how to get it. But yeah it was a 5th to second....definitely went right past fourth by accident.
    Administrator
    May 2003
    Quote Originally Posted by d40winker
    I weep for your valves
    Oct 2003
    Way up high.
    ouch
    Registered User John_M's Avatar
    Sep 2006
    Phoenix
    probably because you hit fuel cut when you redlined the **** outta the motor.....
    Registered User Hytek714's Avatar
    Aug 2005
    Anaheim, California
    no bueno
    Jan 2006
    Ohio
    Go to autozone and they will pull the code for free. They might not be able to tell you what it means, so just write it down so you can look it up. Post your findings here if you don't mind, I'm kind of curious.
    Sep 2006
    NJ
    I didnt get the number but the guy told me it was cylinder one malfunction. He said Im running on three cylinders and I have felt a lag in my acceleration. I was told that it would be wiring or sparkplugs and since Im due for sparkplugs soon, Ill see if that fixes the problem.
    Administrator
    May 2003
    I call bent valve.
    Moderator
    Jul 2003
    Maryland
    I call bent valve.
    +2....revving your ej205 into Vtec land is usaully a bad idea.
    Registered User billedoc's Avatar
    Socal!
    lol vtec land 4 to 2nd? im so sorry
