boost leak -- is my turbo broken?
Results 1 to 15 of 15
This is a discussion on boost leak -- is my turbo broken? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok, so i just bought an '03 wagon, and just realized something: I think i have a boost leak. i ...
    Jun 2006
    Exclamation boost leak -- is my turbo broken?
    ok, so i just bought an '03 wagon, and just realized something: I think i have a boost leak. i have the factory boost guage, and when i accelerate in any gear (as far as i know) the most boost i'll get is about .09. i'm pretty sure that means 9 lbs of boost. And when i get 500rpm or so away from redline the boost drops off. The car does not boost nearly as hard as some of the other wrx's that i test drove either. now i realize i'm retarded for buying it. Also, when i accelerate i hear a whining sound like a dentist drill when i get to about .0 lbs. At first i thought this was just the normal turbo sound, but now im not so sure.
    any ideas on how to check for leaks? or should i just take it to a shop and see what they say.
    p.s. i read some other posts on boost leaks, but i dont understand all this WOT, FMIC stuff like that. im a noob, so plz be nice.
    Moderator
    Jul 2003
    Maryland
    Boost will taper off on the stock turbo towards redline. But it sounds like you might be missing the restrictor pill coming off the wastegate.
    Registered User Robert46123's Avatar
    Jul 2006
    .09 is NOT PSI. The stock gauge shows MPa, and .09 is around 13 PSI. That's a little low for an '02 - '05, but you need to check it in 5th gear starting at around 3,500 RPM. Floor it and see if it doesn't creep to around .1 MPa before it starts to taper. I don't think you have a boost leak.
    2006 WRX WRB Wagon
    Stage 2 Cobb catless DP and Borla Hush CBE
    *Total Loss*
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Make something like this and test your system for leaks. It is very easy.
    Has Any WRX Owners Done Leak Tests for Boost Leaks
    Jul 2004
    elk grove ca
    FYI stock boost is 13.5
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Jun 2006
    Quote Originally Posted by KurleeDaddeeWRX
    ok, so im gonna try this out, and see what happens.
    This isnt going to be bad for my car in any way, right?
    oh, and i looked into MPa (megapascals -- a unit of pressure equal to the force of 1 million newtons per sq. meter... or equal to about 145 psi, which is why the boost guage says .10 - i never noticed the decimal)about being different than psi, and i found this conversion chart...
    http://www.ilpi.com/msds/ref/pressureunits.html
    Turns out that 13.5 psi --which is what stock is rated at -- is about .093 KPa
    hopefully this helps some turbo noobs like myself who scare themselves when reading the stock guage.
    But i'm still gonna try the leak tester thing. lets hope i dont screw my car up somehow.
    P.S. Sorry for the scientific content
    Mar 2002
    San Jose, CA
    Quote Originally Posted by jester458
    oh, and is that other guy right when he said that .09 Mpa is different than psi?
    No. You will need an air compressor to pump up the system and another friend watching your boost gauge. Put it on, presurize the system and listen for leaks. That's it. Super simple.
    Jul 2006
    Yes. The other guy is right...
    http://www.chapelsteel.com/mpa-psi.html
    2006 WRX WRB Wagon
    *Total Loss*
    Jun 2006
    also, i was wondering... so then are boost pressures different in different gears?
    Thanks for all the great help BTW
    Jul 2004
    elk grove ca
    yes, there is more load in gears 3-5, more load = more boost
    14.160@96.011
    90 degree weather
    Jul 2006
    I suggest you start reading all you can in this forum. If you do searches you'll find all kinds of information about your new car. Good luck!
    2006 WRX WRB Wagon
    *Total Loss*
    Registered User rcasTX28's Avatar
    Apr 2006
    San Antonio TX/Provo UT
    Hey, you might also wanna check, or get someone to check, the gaskets for your up and downpipes. From what I've read, that's a common cause of the "dentist's drill" sound you described.
    Before that, you might wanna try the soap and water bottle thing first. If you haven't heard about it, do a search on it. Like the guy before me said, searching saves a lot of time and repitition. But mostly, I think, it helps you to learn things better, since we usually retain info better by applying ourselves as opposed to just hearing someone else say it. Just my .02
    Jun 2006
    ok, so im pretty sure that i dont have any major leaks now, but i think i'll still try making that tester thing.
    But now im wondering what might be causing another problem...
    when i test-drove other wrx's, the turbo seemed to "kick in" a lot harder. You could definately tell when the turbo had spooled up. With my car, there isnt a specific point where you can really tell that the turbo has spooled up: you can't feel it "kick in" at a certain point. any ideas?
    Everything under the hood is stock.
    could it be due to dirty air and fuel filters?
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    This site helps if you're just starting out learning about wrx's or turbo'd cars in general. It helped me when I first got my car.
    http://www.howstuffworks.com/
    http://auto.howstuffworks.com/turbo.htm
    http://auto.howstuffworks.com/question366.htm
    Jun 2006
    thanks amigo
