You say fire like it was actually on fire. If this is true you probaly have a ton more issues. If it was just det. and you melted the piston which caused the motor to cease which caused ur interferance motor to self destruct, then that's semi logical. If you are going with a 2.5 block try to get some sti heads w/ avcs and a good tune.
LinkBack URL
About LinkBacks
