Results 1 to 11 of 11
This is a discussion on RPM Spike = Slipping Clutch? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I first noticed this problem when I was driving to Ithaca this weekend, and I am able to reproduce it ...
    Registered User SwisSlesS's Avatar
    Jun 2006
    Cambridge, MA
    I first noticed this problem when I was driving to Ithaca this weekend, and I am able to reproduce it nearly every time under the same conditions.
    I'm in 5th gear at 2500 RPMs. I press the gas 3/4+ of the way in. RPMs and speeodo climb normally. At 3000 RPMs they spike to around 3500 and then fall back down. The speedo doesn't jump with the RPM spike and everything continues normally once the RPMs drop back down. This doesn't happen if I started at 2250 RPMs or 2750 RPMs or in any other gears.
    From searching I think that this indicates a clutch that's beginning to slip and is on it's way out. Does this sound like the right diagnosis?
    I have a 2002 bugeye wagon with 51,000 miles (about 8,000 of which are mine), Stromung catback and cat-less midpipe.
    Thanks.
    Jul 2004
    elk grove ca
    yes
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Registered User ScoobVee's Avatar
    Mar 2004
    jes
    - Local Riceist
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    si
    Jun 2006
    Cambridge, MA
    I guess I have another question then. Money's tight so I'd be inclined not to do anything about it until it gets a lot worse. Will I cause more damage to anything else by driving on it for a while? Will it be cheaper to replace now than when it's barely driveable?
    Mar 2004
    Get it replaced asap
    Edit: It's cheaper to drive to the shop than it is to have it towed to the shop
    - Local Riceist
    Registered User G4ORCE's Avatar
    Mar 2006
    CA
    Quote Originally Posted by SwisSlesS
    For the love of GOD do it right away, i had a friend with an EVO who drove his car until the clutch went completely out, had to get it towed to the shop, then two hours after we installed an Exedy clutch the engine went out, dealer said due to the clutch (i REALLY highly doubt it). Bottom line its cheaper to change the clutch then to replace the engine
    Registered User bluerex47's Avatar
    Jun 2004
    ohio/texas
    I'll go against the two above and say you do have some time left with it, but it will start to go out relatively fast on you (I drove mine for a month afterwards, and just stayed away from the times when it would slip on me). I would recommend staying away from the situations when it slips (i.e. don't make it slip just to see if its still doing it lol) and start looking around for a replacement. Just for an idea, I got my ACT for $450. You could also replace it with another stocker for a little cheaper.
    - chris
    04 wrx, 04 corvette, 66 GTO
    ACT installed at 36k...new Gears at 44k...
    Jun 2006
    Cambridge, MA
    I'd like to get whatever will increase or at least maintain the longevity of the tranny. I know the tranny is weak, and I plan on driving this car for as long as I can. I'm assuming this would mean OEM, but if there's something better for my goals I would definitely be interested.
    Mar 2004
    Quote Originally Posted by bluerex47
    Never said not to drive it. Of course he has some time left out of it but very little at that. As I said earlier it should be a top priority to get it replaced as soon as he possibly can.
    - Local Riceist
    Jun 2004
    ohio/texas
    Quote Originally Posted by ScoobVee
    ah ok, gotcha
    Look into OEM for sure. I think other people have gone with exedy and are happy. ACT is very nice too, but has a ton more grip...and if you slip up one good time, you can bust a gear like some rotton ole chap I know
    - chris
