Results 1 to 13 of 13
This is a discussion on Battery Keeps Draining! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok heres the deal, it started last winter in michigan, i noticed my volts would go from 14 to 11.5-12 ...
    Registered User mangiardi83's Avatar
    Feb 2005
    howell MI
    Question Battery Keeps Draining!
    ok heres the deal, it started last winter in michigan, i noticed my volts would go from 14 to 11.5-12 when the engine idles. and if i dont drive the car every day the battery will drain and be dead, i take the battery to autozone and recharge it and then it works fine. all the lights dim as well,as soon as i give it gas the volts jump back up. do i have a relay problem? i do have gauges could one of the grounds for those be messed up? maybe a fuse? please help!
    Registered User WRXDriver82's Avatar
    Jul 2005
    Norwich, CT
    Did autozone test the battery? Maybe its a bad cell...
    NEW ENGLAND F4
    TUNERNetwork.com
    Great site for anyone in the north east.
    Feb 2005
    howell MI
    yep autozone tested it after they charged it.it is good it has to be something electrical.but i dont kjnow what .
    Mar 2002
    Calmer than you are
    did you by the car used?
    could be an alternator underdrive pulley.
    go f*** yourself
    Administrator TheJ's Avatar
    Dirty South
    Quote Originally Posted by blarg
    That's what I was thinking.
    -The J
    New Members, CLICK & BOOKMARK these links:
    Feb 2005
    howell MI
    brandnew 05 had this problem last winter, then in spring blew the motor(subaru voided my warrenty) and just got it back with a sti 2.5 short block. and its still doing this
    Mar 2002
    Calmer than you are
    Quote Originally Posted by mangiardi83
    you COULD have said that up front.
    go f*** yourself
    Dirty South
    i do have a underdrive pulley but that may explain the volts going up and down but why the batt draining when it sits for a couple of days
    +1
    -The J
    Feb 2005
    howell MI
    Mar 2002
    Calmer than you are
    do your gauges operate when the car is off? if so, then you hooked them up to constant power rather than switched power.
    sounds like you hooked SOMETHING up to constant power that shouldn't be...and the underdrive pulley is what's making your voltage drop at idle.
    go f*** yourself
    Feb 2005
    howell MI
    you know what i think you are right, it has to be the gauges now i have mine hooked up through the center dash clock wiring is there a better place?
    Mar 2002
    Calmer than you are
    the clock harness is the best place to do it..however, the clock harness has both switched and unswitched power...maybe you just tapped the wrong wire. you want the one that has no power when the ignition is off.
    go f*** yourself
    Feb 2005
    howell MI
    ok would you happen to know the color, or i can get a voltometer and find it thanks
