Results 1 to 2 of 2
This is a discussion on Oil grade/type specified in Europe? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Could a European member please check their owner's manual and tell us if an ACEA A3/B3 motor oil is specified? ...
    Question Oil grade/type specified in Europe?
    Could a European member please check their owner's manual and tell us if an ACEA A3/B3 motor oil is specified? What weight(s) for 10C-45C operating range, and what change interval? I searched for ACEA on the forums and didn't come up with the info.
    Thanks very much!
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    a quick stab....many of the ACEA A3 oils these days are a sythetic 5w30 oil. Europe favors extended oil change intervals. Conventional oils don't cut it.
    You don't need to worry about the ACEA "B" category requirement technically because it's for light duty diesels (such as my car).
