Results 1 to 6 of 6
This is a discussion on Check Engine Light... Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just picked up an 04 wrx. Got a check engine light today and brought it to advance auto they ran ...
    Registered User danNYwrx's Avatar
    Sep 2006
    Upstate, NY
    Just picked up an 04 wrx. Got a check engine light today and brought it to advance auto they ran the code and said it was running too lean. The mods are as follows...
    Turbosmart BOV
    K&N drop in
    ProDrive muffler
    The other mods don't effect the powertrain.
    Any help on what i should do would be great.
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    Quote Originally Posted by danNYwrx
    Turbosmart BOV
    K&N drop in
    ProDrive muffler
    i am wondering if the BOV is causing the code. I know they arent good for a stock WRX, but cant remember if they cause lean or rich.
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Sep 2006
    Upstate, NY
    Just an update..
    I popped the hood and was looking around when I noticed that the hose comming out of the T-valve, that was running to the boost gauge, was torn and all but disconnected. I installed a new hose then disonnected the battery to reset the CEL and it seems the problem is solved. Good thing because I just got the car last night and was a little pissed.
    Registered User AwdTurboWrx's Avatar
    Mar 2004
    Sun Valley,CA
    if you can get stock wrx bov and sell that aftermarket one you'd be good. Plus have some cash for a downpipe!
    The Ghosts of Zooph and Sarcasmo Will haunt CLUBWRX forever!!!
    Sep 2005
    Central NJ
    on newer cars, unplugging the battery won't reset the light.
    Mar 2004
    Sun Valley,CA
    Quote Originally Posted by ChaosStarter
    no but resetting will eliminate light and if you fixed problem it will not comeback. If you don't reset it and you solved the problem, you'll need to drive a little while before CEL dissapears on its own.
