To all suby gurus! Im only boosting 6 psi..help!
Results 1 to 7 of 7
This is a discussion on To all suby gurus! Im only boosting 6 psi..help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; As the title states, im only boosting 6 psi. I recently replaced my stock td04 with an 06 td04 and ...
    Registered User RedlineWRX04's Avatar
    Mar 2005
    Cali
    As the title states, im only boosting 6 psi. I recently replaced my stock td04 with an 06 td04 and now my car wont boost. I checked to see if my gauge was off. It wasnt. I checked to see of there were any leaks anywhere. There were none. I took the hose that conncts to the nipple on the wastegate actuator off and it spiked up hard. I didnt let it hit full boost but it felt better. The only other thing i can think of is the factory boost controler. Any ideas before i go to SOA?
    --04 Java Black Pearl--
    Injen RD 1200 Intake...soon to be gone.im not sure yet...
    Moderator
    Apr 2002
    Greenville, SC
    I'm currently having the same problem; initial research indicates that the boost solenoid sometimes fails, and the usually results in the boost being limited to 6-7 psi. So I'm in the process of trying to source one; I'm hoping to get one this weekend. When I get one I'll let you know how it goes.
    2002 WRX Sedan - 2000 Mazda Miata
    Do us all a favor: work on learning how to drive your car before adding more power. Pretty please.
    Mar 2005
    Cali
    i figured out the problem. Its the wastegate pill. There is a small brass pill that restricts the airflow to the wastegate actuator. I replaced the hoses not knowing that the pill was in there. So i went to subaru, bought the pill and bam, my car is back! Thanks for your input though
    Moderator
    Jul 2003
    Maryland
    When you replaced the turbo did you put the stock resistor pill in or not?
    Also it sounds like you are running off of wastegate pressure...........
    Moderator
    Apr 2002
    Greenville, SC
    Quote Originally Posted by RedlineWRX04
    Where is this pill located? Actually in the lines?
    Moderator
    Jul 2003
    Maryland
    There's a diagram it's actually in one of the rubber lines I beleive cloests to the turbo.
    Moderator
    Apr 2002
    Greenville, SC
    Found it.... looks like mine is in place. Back to boost solenoid for me.
