CEL problem
Results 1 to 9 of 9
This is a discussion on CEL problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; When I was underneath my dash today I saw a connecter that was unplugged, so being the curious person I ...
    Registered User MarkF4E's Avatar
    Apr 2006
    Philly
    CEL problem
    When I was underneath my dash today I saw a connecter that was unplugged, so being the curious person I am I connected it. When I went to drive my car again the CEL came on. I disconnected the cable I had connected and the CEL turned off again. I have an up-pipe, and the EGT sensor is not there anymore. However there is a resistor there. Is there a certain amount of Ohms the resistor needs to be? Im attaching a pic of the connector, if you know what it goes to please speak up. The connector is the two green pieces in the picture (shown disconnected).
    Wheel Painting Guide
    Bugeye Mafia Mbr #86 Takin it to da matresses.....
    Kennett Fire Company No. 1 Station 24
    Wait, I think you're talking about two different things. The CEL you saw is one you evoked by going into diagnostic mode -- it was rapidly flashing, correct? See this:
    Help! Green connector under fuse box not connected
    Now, as far as needing a resistor, yes, the value is specific. However, since your car already has one in place, and your car is not throwing a CEL unless you mess with the green connector under the dash, I don't think that's a problem. You might search for "resistor" and "value" and "CEL" for more details, but in any case I think it's a moot point.
    SD
    Apr 2006
    Philly
    Wow, thanks for the response. I am much much happier now.
    Quote Originally Posted by MarkF4E
    Great, cheers!
    SD
    Moderator
    Jul 2003
    Maryland
    +2 for SD_GR's comment....2 seperate things and it's the test connector.
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    Sorry to highjack but this is good info.
    Does the diagnostic wire need to be connected to read the OBDII codes? I tried to have Autozone scan for my CEL and it kept erroring out with a "Link failed" message. I will try going back with the connector attached.
    The other question, what is the correct resistor value? The car I just got has the EGT wires broken off at the sensor and the pigtail removed. I can jamb a resistor in the female plug end but don't want to create more problems than solutions....
    Thanks again for any help!
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
    Sep 2006
    Albuquerque, NM
    Ok I think I answered both questions ( search engine saves the day ).
    The recommended resistor value was 2.2K ohm. I inserted one into the female connector and presto, running much better.
    I then went back to Autozone and the scanner connected no problem ( without connecting the diagnostic wire under the dash ). One code was for the EGT, no surprise, one was for fuel cutoff, also probably from the EGT, and the thrid was a mystery. P1131, "Manufacturers Specific Code" with no other info. I'll hit the search again but has anyone seen this?!?
    Sep 2006
    Albuquerque, NM
    Fixed
    I found the P1131 code definition, "Front O2 sensor short bank1".
    Decided to trace the wires and found a crimp point near the connector hidden by the heat shrink. Cut and snip, all is good and the CEL is out!
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    Quote Originally Posted by ktmrider
    ktmrider - 1 , CEL - 0.
    Good job, way to be a problem solver.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
