Oil Consumption Problem?
Results 1 to 15 of 20
This is a discussion on Oil Consumption Problem? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I noticed my car was a quart shy today. I'm at 14,000 miles. I've been changing oil by the book, ...
    Registered User FUNKED1's Avatar
    Jun 2002
    Pleasanton, CA
    I'm at 14,000 miles. I've been changing oil by the book, break-in change then 7500 miles then 15000 miles, so on and so forth.
    I've never had a car use a quart between changes this early in the life of the car. So I'm kind of pissed off at Subaru.
    Do you think I have a problem here or should I chill the heck out?
    FUNKED1
    GO PETTER & TOMMI!!!
    Nov 2002
    Mechanicsburg, PA
    I have been thinking about making a poll on this subject. I use about a half quart evry 3K to 4K miles ... every oil change. I switched to Mobil 1 5w30 at ~19K. I think my oil useage is a bit on the skimpy side. I now have ~29K miles. Most of my other vehicles' oil usage has been about 1 qt. every oil change ... maybe a bit more. Just enough that you get the oil changed vs. add a qt.
    My WRX is not a commute vehicle & most of the miles have been on long hauls vs. others I have had. I do not think your situation is a problem nor do I think mine is. Both cars may actually use about the same amount if driven identically for a while ... which won't happen. The point is, day to day use affects oil consumption & it is not just an engine wear thing. My $.02
    Registered User djrez4's Avatar
    Colorado
    FUNKED1: You really should be changing your oil more often than every 7500 miles, especially if the dealership is changing your oil for you. That's over twice the recommended milage between oil changes.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Put mine in the never changed a drop column.
    Also put me in the 7500 miles?!?!? column.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jun 2002
    Pleasanton, CA
    Do you guys have any input about the oil consumption? Do you think 1 qt in 6500 miles is excessive or am I having a cow over nothing?
    About oil change intervals:
    7500 miles is what the owner's manual says.
    I use Mobil1 which should extend oil life. With that oil I'd think the recommended oil change intervals would be more than sufficient.
    FUNKED1
    Jun 2002
    Pleasanton, CA
    Thx, sounds like I'm probably overreacting.
    It's just that my Hondas never used any oil at all at this mileage!
    FUNKED1
    Colorado
    After working at a Subaru dealer for a while, I can assure you that the owner's manual doesn't say 7500 miles. It says 3 months/3000 or 3750 miles. You're 2002 WRX service manual can be found here.
    Either way, you can never go wrong changing your oil more frequently. If you don't change it enough, you get problems.
    EDIT: Chris....whatever are you talking about?
    Jun 2002
    Pleasanton, CA
    Ummmmmmm your link shows 7500 mile intervals.
    There is a note about severe driving conditions with the intervals you mention in your post though.
    The information is identical to what is in the manual.
    I wish you guys would put as much energy into answering my question as you do trying to prove me wrong on some tangential point.
    FUNKED1
    Jun 2002
    Pleasanton, CA
    PS I realize you guys are trying to help, thx!
    FUNKED1
    Jun 2002
    I have no idea!
    I meant it's never USED a drop. I did change it at 15k miles though.
    I think the reaction Rez and I are having is that we have no idea how much it'll use in 7500 miles 'cause we've never left oil in that long. It does seem excessive though. Like I said, mine's never used a drop. 2000 mile oil change interval on mine. Zero times 3 is still zero, but...?
    Chris
    1993 Honda CBR600F2
    Registered User WRXed's Avatar
    Nov 2001
    Macon, GA
    Every engines burns oil as it runs. No engine is perfectly sealed. Having said that, I don't really have a good idea of what constitutes average or above average oil consumption. Perhaps NJSubieTech can shed light on this subject.
    On the oil change interval; I personally don't change oil every 3K miles, but instead use every 5K as a changing point. This is due primarily to "laziness" in that I do it myself and it's way easier for me to remember intervals of 5 than 3.
    All those who believe in psychokinesis, raise my hand. - Steven Wright
    Moderator, of the "Super" persuasion
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    i don't burn or use any oil.
    betty keeps it all. i test regularly, and change with mobil 1 5weight every 5K miles.
    dR
    Nov 2001
    Macon, GA
    dR
    I'm sure you do, it's probably such a small amount that you'll never notice. Afterall, the dipstick isn't *that* great of a measuring device. I suppose my point was to not be alarmed at the fact the engine is burning some oil. If it's burning a quart every 3K miles, then I'd worry about it.
    Aug 2001
    The Hub
    agreed, however, if whatever oil i lose is not measurable, i prefer to think i'm sealed up great. losing a quart every 3K miles in NOT standard. i would be concerned about proper break in of the seals if they are leaking that much.
    i might even run a compression test.
    dR
    Colorado
    Sorry FUNKED! I'm not trying to be an ass. Chris and I are just worried about your car and want it to last a long time for you!
    The service manual is kinda of confusing to read. The intervals across the top aren't telling you when you should get your car serviced. They're telling you what to perform every time you reach a multiple of that milage. Basically, every 3750 miles, you should do an oil change unless the milage falls under one of the other columns, in which case you should perform the more extensive service. Every multiple of 7500 miles is an oil change and tire rotation. If i'm not making sense, just tell me!
