Just installed LED blinkers but....
Results 1 to 9 of 9
This is a discussion on Just installed LED blinkers but.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed some LED bulbs for my blinkers and now for some reason my blinkers blink oddly fast. Like ...
    Registered User The An$wer's Avatar
    Jan 2006
    Modesto, CA
    I just installed some LED bulbs for my blinkers and now for some reason my blinkers blink oddly fast. Like ricy fast.. anyone have any ideas? I searchd and cant realy find anyone with this problem. I have an 06 WrX if that helps... someone said something about a electronic flasher.. anyone know how hard that is to install? Do i have to wire it in?
    Registered User DJSHADOW7's Avatar
    Aug 2005
    AZ
    Quote Originally Posted by The An$wer
    I think the problem is the bulb is drawing too much current. IIRC thats what makes it flash to fast. My guess would be to try a different bulb. Try Google.
    ...If you ever need anything please don't hesitate to ask someone else first.
    Blobeye Syndicate numero uno.
    Nov 2003
    Montreal
    Usually LED's are low draw and may need a load equalizer for them to work properly. You can get them at custom motorcycle shops as lots of Harley owners replace their stock lights with LEDs. Kuryakin makes one and there are sure to be others.
    Mods: VF34,TMIC, Up pipe, Dp, full catless, Ecutek, Stoptec brakes, DMS 40 coil overs, ALK, CUSCO subframe, Sparco seats, Exedy twin plate and more that I can't remember.
    Registered User audio's Avatar
    Dec 2004
    houston,Tx
    +1 for the blub, make sure its making contact with all the contact points in the socket, you may have to move/bend them on the bulb
    Registered User TOOFAST88's Avatar
    Oct 2005
    Champaign/Buffalo Grove, IL
    The blinkers don;t draw enough current, therefore they will blink faster.
    COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
    Blobeye Syndicate #2
    RYB - 01
    "RALLY ON"
    Quote Originally Posted by StreetSlider
    Hellen Keller's favorite color is Blobeye Syndicate.
    Nov 2003
    Montreal
    Quote Originally Posted by TOOFAST88
    Yes thats why he needs a load equalizer.
    Aug 2005
    AZ
    Ah i knew it was something like that. Had it mixed up.
    Oct 2005
    Quote Originally Posted by DJSHADOW7
    S'all good
    The blinking speed should be proportional to the current. So if these bulbs only draw half of the stock current, they will blink twice as fast
    RYB - 01
    "RALLY ON"
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    led's carry almost no resistance so they blink like its a busted standard bulb.
    you can wire in a resistor to fix that.
    2006 Aspen White STi
    Stage 2 Open Source Road Tune
    A bunch of bushings from TiC
