Seafoam Questions
Results 1 to 15 of 24
This is a discussion on Seafoam Questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just went to the local autoparts store and purchased some seafoam. my question is how is the best way ...
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    Seafoam Questions
    I just went to the local autoparts store and purchased some seafoam. my question is how is the best way to use it. if i slowly suck it up using the vacuum line to the bypass valve, or in the tank. the bottle says each way helps clean different things.
    thanks for your help,
    ryan
    07 white STi in CT
    Jun 2006
    NW ct
    sorry i clicked submit three times. mods could you please delete the other ones?
    07 white STi in CT
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    wow, tripple post.
    you can use it in your gas tank to clean the fuel system and injectors OR you can inject it through the intake to clean the valves and carbon deposits. when i used it, i noticed a slight gain in mpg, but that was only temporary
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
    Jun 2006
    NW ct
    Quote Originally Posted by WRX13oy
    wow, tripple post.
    do you think i could use it half and half to clean both or just do one at a time?
    07 white STi in CT
    Jul 2003
    SOCAL!! 91752
    ya, you could do half. or you can just buy 2 bottles
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    how often should one do this ?
    Jul 2003
    SOCAL!! 91752
    once a year is good. my friend uses it everytime he changes his oil. so i guess it depends on how often you want to use it
    Jun 2006
    NW ct
    if i suck it therought the vacuum line to the bypass valvedo i have to disconnect anything else? and did you mix the seafoam half and half with gas?
    and i heard people said they locked their motor by just sucking it out of the bottle and one should pour it in the vacuum hose. if i poured half of the bottle in a container and slowly sucked it in would that be ok ro should i just use a funnel?
    sorry for so many questions but i have never done anything like this before. all i have done is exhaust and intake shortshifter, springs, and the accessport.
    once again clubwrx.net has helped so fast. thank you guys.
    07 white STi in CT
    Jul 2003
    SOCAL!! 91752
    just have the hose slowly sip the seafoam. people lock their motors by dumping all of it in the motor or sticking the hose all the way into the seafoam which is a NO NO.
    Jun 2006
    NW ct
    thanks alot. im gonna try this later. i'll let you know how it goes.
    07 white STi in CT
    Jul 2003
    SOCAL!! 91752
    i have a video of me using seafoam on my wrx. its still on the tape and havnt had time to stick it on my computer
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    I use it about once a year... I use a third of the bottle in my gas tank, a third goes in my oil, and the rest gets fed into the engine via one of the vacuum hoses. I usually put the stuff in my oil and gas tank and when the tank runs up I change the oil soon there after...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    Apr 2004
    Southeastern PA
    Quote Originally Posted by MidKnight
    How do you add it to the vacuum hoses?
    Mods & Pics
    Jul 2003
    SOCAL!! 91752
    i usually do it through here. i have a separate hose that i attach to that spot
    Apr 2004
    Southeastern PA
    With the engine running?
    Mods & Pics
