When should I change my timing belt
Results 1 to 12 of 12
This is a discussion on When should I change my timing belt within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2004 wrx with 50,000 miles on it. I was wondering if I should be thinking about changing ...
    Jul 2006
    Omaha, NE
    I have a 2004 wrx with 50,000 miles on it. I was wondering if I should be thinking about changing the timing belt soon. If so, where is the best place to get one and are there any packages that would improve performance?
    Check your owner's book for the maintenance reqs. Mine says 105K.
    - Al Stewart
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    if you do a timing belt you could also think about replacing the clutch and/or upgrading it..not sure. The labor may be beneficial to do both.
    I've heard anywhere from 60k+ for the timing belt. A lot of people I've talked to said you can go higher like 75-90k.
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    90k is typically what dealers say -- our long time subaru tech also says the same. better doing it slightly early rather than waiting too long and having it break. 17k more and my timing belt and water pump will both be changed.
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Jul 2004
    elk grove ca
    had my timing belt replaced at 69k miles due to timing belt tensioner failure.. they did everything at the same time
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Registered User Jje121's Avatar
    Jan 2005
    Fitchburg, ma
    I just hit 70k anyone know about how much it will run me to get my timing belt done?
    New England F4
    Bugeye Mafia
    2004 GMC Sierra 1500
    03 Subaru WRX (SOLD)
    01 CBR 929 (SOLD)
    Quote Originally Posted by blarg
    nothing funny about stubble on the man-marbles.
    Feb 2006
    Midwest
    I've heard anywhere from 250-400. I had my engine replaced so the labor was already there
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    Quote Originally Posted by Jje121
    If you're mechanically inclined do it yourself. On a longitudinal engine like ours it's not too hard. Pull the radiator for some room, pull off the drive belts and crank pulley, remove the covers and change the belt. No dropping the motor half out etc like in a FWD car. Change the water pump while you are in there as well.
    It must be on the Subway diet. Did you name it Jared?
    Registered User 06grayrex's Avatar
    Mar 2006
    STL
    My service manual also says 105,000mi, inspection should be done a 30k,60k,and 90k then replace at105k
    Hawk-Eye Alliance #666
    Stage 2
    One reason I hesitate to do it on my own -- and I only bring this up for the sake of showing one possible advantage of going to a shop or dealer -- is what one might uncover by removing the front cover (pardon the pun). If there are leaky seals, a tensioner issue, or anything out of the ordinary under there I'd hesitate to take the job on at my house, and at that point I'd have the car apart as well. Just to avoid that, I'm thinking of supporting the auto repair industry and have it done when the time comes. Just a thought.
    - Al Stewart
    Registered User Thug Nasty's Avatar
    Jul 2006
    Denver CO / Portland OR
    I changed to timing belt on my older FWD car. It's a PITA, but it gives you a nice sense of accomplishment when you turn on your engine and it isn't broken.
    -John
    Different Strokes
    Dirty Crew #2002
    Mods in profile.
    Jul 2006
    Omaha, NE
    Thanks for the advice guys. I think i'm gonna change it at 60k. while I'm at it I will also replace the water pump and the timingbelt tensioner. does anyone know if there are any timing belt packages out there that I could get which would have all those things in it? we just changed all those things on my buddy's A4 so I think I will do it myself as well.
