HELP wierd noise coming from engine
Results 1 to 14 of 14
This is a discussion on HELP wierd noise coming from engine within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; somewhere in front of the driver in the engine i am hearing a strange noise. it only happens while accelerating ...
    Registered User wakeskate23488's Avatar
    Mar 2006
    Ocean County, NJ
    somewhere in front of the driver in the engine i am hearing a strange noise. it only happens while accelerating really. Kinda sounds like a wierd whistling. Not like the exhaust but like somethings not right and kind of bothering me. It kinda sounds like the wind in a wierd way, if anyone else ever had this please let me know or what you might think it is. I cant really describe it too well though. -thanks
    Jul 2004
    elk grove ca
    turbo spooling?
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Mar 2006
    Ocean County, NJ
    oh that must be it. no u idiot im not stupid, its something else
    Jul 2004
    elk grove ca
    well you do a lame piss poor job of describing this "weird sound", i make an obvious suggestion, then you rip me... right on! you are going to get TONS of help that way
    14.160@96.011
    90 degree weather
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Quote Originally Posted by wakeskate23488
    not cool at all.
    Did you change your winter air out for summer air in your tires? I've heard of that causing issues like this.
    Registered User orvtech's Avatar
    Nov 2005
    Miami
    Quote Originally Posted by blackrex02
    +1
    try adding some suggar to your gass tank, that sound is very common in F4 engines with low glucose.
    Registered User Gabewillwin's Avatar
    May 2006
    san diego
    guys, you are totally misleading his guy, rude answer or not i think its pretty obvious that his clock spring has given out on him.
    If you ever go back in time, dont touch anything.
    2005 STi
    Cobb Ap Stage Two/ Cobb Suspension Stage one.
    Nov 2005
    Miami
    hijack!!!
    so... how about this heat wave ?
    Jul 2004
    elk grove ca
    i suggest checking your halogen fluid to make sure its at proper levels, and your muffler bearings also since those make a " wind" noise when they go out
    14.160@96.011
    90 degree weather
    May 2006
    san diego
    muffler bearings! why didnt i think of that
    2005 STi
    Nov 2005
    Miami
    it is just low in blinker fluid!
    Registered User 02nighthawksi's Avatar
    Nov 2005
    Tampa, Fl
    Take an exhaust sample and send it to Motec Systems, you may have blown the welds on the intake causing the whistle.
    06 Protuned Stg2 WRB WRX
    Hawk-Eye Alliance #123
    Jul 2004
    elk grove ca
    dude, its gotta be the wind wooshing through your crossdrilled brake lines
    http://kalecoauto.com/index.php?main...&products_id=1
    14.160@96.011
    90 degree weather
    Jul 2004
    elk grove ca
    heres where you can get replacement muffler bearings
    http://kalecoauto.com/index.php?main...roducts_id=10:)
    14.160@96.011
    90 degree weather
