RPM spikes HELP!!
Results 1 to 10 of 10
This is a discussion on RPM spikes HELP!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am new to this forum and fairly new to the WRX/Performance car scene. I got a 2002 WRX from ...
    Apr 2006
    RPM spikes HELP!!
    I am new to this forum and fairly new to the WRX/Performance car scene. I got a 2002 WRX from a friend of mine about four or so months ago. The only routine thing I've had to do is change the brake pads. No problem. I don't know too much about cars but, know much of the standard things to do. A new problem occurred recently and that was the RPM spikes and then lowers when I accellerate *too* fast? It will usually occur in fourth and fifth gears, but, has also in all the others. The RPMs will spike and then fall back down to where they should be. The car doesn't seem to gain any power from this and I also know it is irregular. Also it seems to be losing power in general. I went to the dealership and they guy wanted $90 for a diagnostics check. I don't have a lot of spare money and probably won't for a while. I was hoping someone could help me or give me some ideas and some things to check for. I appreciate it.
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    does this happen when you shift or just randomly
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Registered Whippersnapper mustangtx63's Avatar
    Mar 2005
    If this happens when you shift, the problem is sloppy footwork.
    I had the same problem when I first got my wrx.
    ~ Retired Blobeye Syndicate #063 ~
    2011 Ford F-150 ECOBOOST 4x4
    Apr 2006
    York, PA
    Quote Originally Posted by mustangtx63
    +1... if this is the problem
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Oct 2005
    Late Devonian
    So you have it in 4th or 5th gear, floor it, and the RPMs rise above the point where they should be for that speed? If so, your clutch is shot (sorry). I'm pretty confident on that being the only potential explanation. Your going to have to baby it until you can get it replaced.
    Apr 2006
    Damn! Yeah it's not when I shift. My first car was a manual and that's all I like to drive. I appreciate the suggestion but, I know how to shift I think it is the clutch. Any ideas on how much that will cost me or suggestions on aftermarket clutches?
    Moderator
    Jul 2003
    Maryland
    Get an OEM equivlant or a little stronger if you like. Getting strong (good grabbing clutchs) will almost always mean you'll break a gear.
    Mar 2005
    Quote Originally Posted by 302@12psi
    +1 for OEM.
    Registered User Fuchs's Avatar
    Feb 2006
    Midwest
    New Clutch Kit
    Sounds like that's your problem.
    Apr 2006
    hey thanks for all the help guys. Much appreciated.
