squealing
Results 1 to 7 of 7
This is a discussion on squealing within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have done everything that i could think of to stop it but i cant get rid of it. changed ...
    Jun 2005
    Honolulu
    squealing
    i have done everything that i could think of to stop it but i cant get rid of it. changed belts, adjusted tensions etc. what else can i do?
    Registered User REXtard04's Avatar
    Mar 2006
    Rochester, NY
    Quote Originally Posted by cabbage
    Try to be a little more specific on the problem if you are looking for help.
    Where is it coming from exactly? Try to pin-point the location.
    When does it occur? Does it do it ALL the time, or only under certain driving conditions?
    What type of "squealing" noise is it?
    Answer these questions and come back with some more info.
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Pigs usually squeal on their way to the slaughter house.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Jun 2005
    Honolulu
    its comming from the engine bay and ony happens at startup and normally goes away after a few moments. the temperature out side seems to have someting to do with it also. the colder it is the longer it happens for. and it only stars when i engage the clutch. it sometimes happens in idle but only everyonce in a while.
    Registered User madmaxwrx's Avatar
    Oct 2008
    mundelien,IL
    same problem
    i have to same problem its when i start up i think its the alternator becasue i sprayed some wd40 where the alternator spins and it went away it only work for a few seconds tho idk its annoying tho that for sure. i was thinking it was the belts too. i just dont know
    Registered User pfsquirrel's Avatar
    May 2008
    NJ
    Quote Originally Posted by cabbage View Post
    I have the same thing. Someone suggested it could be the throw-out bearing.
    Registered User atrizzzie's Avatar
    Sep 2008
    Seekonk, Massachusetts
    check your idler pulleys. if there is ANY black rubber looking build up replace the pulley and belt
