Which Optima do I need?
Results 1 to 9 of 9
This is a discussion on Which Optima do I need? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My battery finally crapped out on me yesterday morning. The car is 4 years old with 70K so it just ...
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    My battery finally crapped out on me yesterday morning. The car is 4 years old with 70K so it just needs a new one. I'm going to go with the Optima red top battery, but I need to know which specific model I should get.
    Thanks for the help.
    Try not, do or do not. There is no try. - Yoda
    Mods
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    i believe its the 37/75r ....youll need the reverse terminal one
    2006 Aspen White STi
    Stage 2 Open Source Road Tune
    A bunch of bushings from TiC
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    I got my Yellow Top from Remy Battery model D35.
    You want the 35 size part#8020-164 Red Top http://www.remybattery.com/Optima-Ba...10-35-910.html
    If you ever run accessories off the battery when the engine is not running you might want to consider the Yellow Top though as it is a deep cycle.
    It must be on the Subway diet. Did you name it Jared?
    Mar 2004
    USAF
    Why will I need the reverse terminal one? My positive terminal is on the left and my negative on the right.
    Also, I was considering the yellow top also, but unsure if I really needed it.
    Mods
    Registered User AKESREX's Avatar
    Oct 2004
    So. California
    The 8020-164 Optima red top is what's in my '02.
    The yellow top is a deep cycle battery, which has a few different qualities
    when compared to a red top starting battery. The yellow top is intended
    to be drained down fairly low and then recharged fairly slowly. My guess
    is that you'll get a somewhat lesser life out of the yellow top when used
    to start a car.
    Oct 2004
    So. California
    It's a BCI group 35. Got it from Summit for $120.
    Mar 2004
    USAF
    My only concern is that I always listen to the radio in my car while I wash it. I thought the yellow top would be better suited for this. Are you saying that the red top would do fine in that capacity?
    Mods
    Jul 2005
    Ventura County,CA
    yeah it will be fine.
    i have my stock battery and i listen to the radio for hrs at a time and it still starts up fine after. however i have the stock system
    so if you have a system put in youll problably be better off with the red or yellow top.
    Oct 2004
    So. California
    Guess it depends upon how much "radio" you've got. If it's factory, don't bother
    with a yellow top. If it's significantly stouter, you may want to do a deep cycle.
    I'm just concerned that you'll get like 2 years out of the battery (yellow top) and
    wonder why. The last red top I had in the race car went about 7 years- I only
    replaced it out of fear that it would crap out (at the worst possible time with my
    luck). I'm sure I could have gotten another year or two out of it......
