Random engine lights
Results 1 to 15 of 18
This is a discussion on Random engine lights within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I bought my 2002 WRX 4EAT wagon last year. I added a BOV and since then the AT OIL TEMP ...
    Jul 2006
    Upstate NY
    I bought my 2002 WRX 4EAT wagon last year. I added a BOV and since then the AT OIL TEMP light comes on when I punch it in the rain...went to dealer, no big deal they said. It always clears itself out when I restart. Anyway here is my question...
    I was driving the other day with the A/C on. I parked the car, and when I hit the brake the ABS light flashed on as the car almost bogged out. I know the A/C drains the power, so I disregarded it. On the rest of my 260 mile trip, when I was cruising on the highway, if I hit the brakes the ABS light and AT OIL TEMP light would flash on and the speedometer would drop. The car was still running fine, so maybe an electrical problem???
    Any info. is appreciated, I am driving from NY to CA next week and need to know if something may need replacement...
    Thanks,
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    take off the BOV, it will solve all of your problems just do a search and see why not to add a BOV
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Jul 2004
    elk grove ca
    completely disregarding that BOVs suck on wrxs.. why on gods green earth would you put a BOV on a 4EAT anyway?
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Administrator
    May 2003
    Quote Originally Posted by bkotzman00
    I don't care for BOV's, but how is removing it going to solve the problems?
    Jul 2004
    elk grove ca
    cuz BOVs cause simultaneous suckage of everything on our cars
    14.160@96.011
    90 degree weather
    Registered User armysti's Avatar
    Apr 2006
    tucson AZ
    the bov wouldnt have anything to do with the abs light coming on. it sounds more electric to me.
    Apr 2006
    tucson AZ
    i would take it into subaru and get it looked at before u head home. just to be on the safe side.
    Apr 2006
    York, PA
    my bad, took to quick of a look at the tread and saw that a BOV was installed and assumed that all of the problems were related to that, my bad I was wrong. but to me it sounds similar to when my alternator went bad the voltage would drop and when that happened the speedo would blip and the various lights on the dash would come on. not sure but does the brake system need electricity to power the master cylinder so when pressing the brakes causing a voltage drop?
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Jul 2004
    elk grove ca
    i still think its the BOV
    14.160@96.011
    90 degree weather
    Apr 2006
    York, PA
    yea the BOV has to go. but go to an Auto Zone and have your alternator checked - its free and couldn't hurt to check to see if that is causing the problems.
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Did you verify all vacuum lines are plugged/connected when you swapped out the BOV? The conditions under which these issues are occuring sound suspiciously like low vacuum conditions to me. Thus, a vacuum leak could be the culprit.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jul 2006
    Upstate NY
    I removed the BOV today. It was installed correctly, very easy install.
    I put it on because yes it is a 4eat, but still makes the sound as soon as you let off the gas. Making the noise was the purpose. It is more or less my wifes' car and she likes the noise.
    It may be the alternator, it would make sense, but it hasn't really gotten much worse(besides the lights) and it has been doing it since Oct 06.
    Hmmmmmm...
    Jul 2006
    Upstate NY
    I was searching other forums...does it sound like the alternator ground maybe...
    Thanks for the info.
    Jul 2006
    Upstate NY
    Wanted to let you know I removed the BOV and cleaned the terminals...everything is great now...thanks for the help!
    Jul 2003
    PA
    Just cleaning the terminals eh? wow..whodathunkit
