Random engine lights - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Random engine lights within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; didnt i say it was the BOV?...
    Jul 2004
    elk grove ca
    14.160@96.011
    90 degree weather
    airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
    Registered User Sleepwagon1's Avatar
    Jun 2006
    Asheville, North Kakilaki
    Seriously... Check belt tension... If belt starts slipping and alt. isnt charging right it WILL cause those lights to come on. Had serp. belt on H6 motors and alt. belts on wrx's break and had the same prob. Also it could poss. be an alt. prob. DO NOT GO TO ADVANCE OR AUTO ZONE to have alt checked. Take it too a reputable shop that spec. in Jap. cars and ask them to test alt. check belts etc. and if alt. is undercharging to do a full check of all connectors on alt. and wiring...While its there have them scan the ABS system for trouble codes. It will give you a good idea of whats going on...AND it sound kinda like a belt in the way that it does it under heavy accel. when its raining...Think about it...
    Registered User jaqattack02's Avatar
    Sep 2005
    Richmond, Va
    Quote Originally Posted by bkotzman00
    not sure but does the brake system need electricity to power the master cylinder so when pressing the brakes causing a voltage drop?
    Master cylinder shouldn't but the brake lights coming on probably will. The lights take more power than most people think. Incandescent lamps are the most ineffiecient type of lights available, but they're cheap, so they're popular.
    Blobeye Syndicate #035
    Cobb Stage 2
