had a compression test done? how many miles? you said youve done all the regular mainenance stuff.. so im not sure
This is a discussion on Gas mileage please help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I bought my 2002 WRX brand new 4 years ago. About a year ago, my gas mileage dropped off tremendously. ...
I bought my 2002 WRX brand new 4 years ago. About a year ago, my gas mileage dropped off tremendously. It did not coincide with anything done to the car and it happended fairly quickly. I have no after market mods... I drive all highway miles-- 200 miles to and from work on the interstate. I am getting about 19 to 21 MPG. I used to get much more than that, I'm not sure exactly what I used to get, but I know that when I've driven to Florida and back from Connecticut I was probably going almost 400 miles without filling up. Now I'm lucky if I get 280 miles (all highway going 65 MPH!). I've brought it to 3 separate mechanics and the Subaru dealership (I was desperate)---had every diagnostic test done, changed filters, adjusted fuel trim, etc etc. Every body is stumped, including myself! Has anybody had this problem or have any suggestions? Thanks!
14.160@96.011
90 degree weather
airhog, removed silencer, and removed stock catback exhaust (stock DPs in place) and craptacular california 91 octane piss water
What about alignment and tires? Tire pressures?
2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
true! is there junk in your trunk? did you go an abnormally long time between oil changes?Originally Posted by dcpatters
14.160@96.011
90 degree weather
The compression test is a good idea---I haven't done that yet. If the compressions are off, what next? The car has just about 60,000 miles on it. As far as tire pressures and oil changes go, well--I'd have to be a fool not to have thought of that already!Originally Posted by blackrex02
This is almost a 10 mpg reduction, so its something big. I was also thinking it could possibly be the injectors. I don't know too much about those but I was told it is hard to test a fuel injector.
Check and clean MAF sensor, check o2 sensor. Check or replace knock sensor, when mine went, I lost some big time gas milage. Car still seemed to run OK, maybe just a little less power... but when I changed the knock sensor out then I noticed a major improvement in gas milage and some power gain.
'02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had.'09 STi stage 1, hope this one will be good too...
I get about 19 to 21 in my 02. I always have with mixed driving 24 or 25 with pure freeway. I try to get about 300 miles out of a tank. I used to use premium now I use mid grade with the same result.
Yeah I used to use 93 octane I find that 91 is just as good but around here its hard to find 91! So I pay my $3.20 for 93 and try not to think about it.Originally Posted by Droopy
I'd be happy with 24-25 but my 19-21 is pure freeway. I get about 18 city. I did add some expensive fuel injector cleaner and I got about 24 mpg for about 2 tanks but then it dropped back down again.
How much did the knock sensor cost?Originally Posted by wrxdrvr
It cost me 125$ but that's Canadian, so it should cost you less.Originally Posted by chemical09
3.20 for 93?>!?#@!@ im paying like 3.70 for 91.... stupid san diego!
my car is an 02 as well...and i always get 300 on a tank and tops like 320 b4 the warning light goes off...u say changing the knock light wud improve mpg...i guess were all looking for ways to imrpove milage w gas being ridiculous!!!
my car is an 02 as well w 43k on it...i get usually over 300 but the warning light will go on probably around 320...u sed changing the knock sensor wud improve gas milage...w gas prices today i guess were all looking for ways to get better mpg....its ridiculous!!!!
wantd to change knock light to knock sensor...silly me
