Help with wrong oil filter install mistake
Results 1 to 2 of 2
This is a discussion on Help with wrong oil filter install mistake within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Please help... I need to know if I should take off a K&N HP-1004 (2.0L non-turbo) oil filter I put ...
    Registered User boosted scoob's Avatar
    Aug 2004
    Robins AFB, GA
    Exclamation Help with wrong oil filter install mistake
    Please help...
    I need to know if I should take off a K&N HP-1004 (2.0L non-turbo) oil filter I put on by mistake when I chenged my oil today. I must have misread the cross-reference at the auto parts store. The one for the turbo 2.0L is HP-1008 and it's significantly smaller. Will this damage the engine or am I ok for another 3k miles?
    Thanks.
    02 WRX - XS Power header/UP/TBE, XS Power FMIC, MBC@15psi, Ported TD04L, Perrin shortram, Alum Radiator - 13.35@101
    05 Mini Cooper S - Bone stock
    95 Mustang GT conv. (Work In Progress) - BBK LT headers & h-pipe, dumped Flowmasters, Kirban AFPR, BBK subframe braces, 6-point rollcage, FMS springs, 70/30 struts, 50/50 shocks, K&N intake
    Moderator
    Jul 2003
    Maryland
    I'd swap them out ASAP. The larger filter will probaly hold more oil and while it probaly isnt a devasting mix up, with a turbo car that depends on oil for more then the motor I'd want the right filter on. Also the filter from 02-03 is a different size so maybe that was the mistake. I'd get the right filter on their.
