Results 1 to 3 of 3
This is a discussion on idle air sensor ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im having problems with when my fans or ac is on, my car wont idle or when i get on ...
    Registered User speeddr2000's Avatar
    Mar 2005
    jacksonville
    idle air sensor ?
    im having problems with when my fans or ac is on, my car wont idle or when i get on the gas it wont go over 2000 rpms. i have the resestor mod done the uppipe cat and downpipe cat is removed. when im at cruise or up too speed the car runs fine. some one told me the air idle sensor but where the hell is that. i have been noticing that the gas light on my car is staying on when i start my car for like 2 mins or so but i will have 3/4 or 1/2 a tank of gas still . help
    Registered User nom0ny's Avatar
    Jul 2004
    Toledo
    Sounds like you have a lot of other issues...
    ...but the idle air sensor is held on by 2 screws and is located right below the intercooler, on top where the big air hose goes up into the intercooler. It is grey where the screws hold it on, with a black sensor top part that the electronics plug into to. It is just the top portion, you don't have to unplug any hoses. The part # is 22650AA182 but you will also need to order the gasket if you want to replace or clean it.
    I was having idle problems where my car was idling way too high and not holding a steady idle. The part I took off has a lower part # than the one I put on, so I imagined they changed something for the better.
    It costs like ~$280 so I would make sure you are getting CEL codes indicating that is malfunctioning.
    Wrinklechops
    Quote Originally Posted by nom0ny View Post
    What is just the gasket's part #? 22650AA182 isn't bringing anything up for me anywhere
