i threw a p0171
Results 1 to 8 of 8
This is a discussion on i threw a p0171 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; system to lean i dont have a MBC or a CAI and im running cobb stage 2 map. it just ...
    Jun 2005
    ct
    i threw a p0171
    system to lean
    it just came on, and i only drove about 10 miles with it on. i read somewhere that it could be caused by an 02 sensor? but i dont know
    any help here?
    vf22 Stage IIII wagon of DOOM
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    Check all your hoses. When my FPR hose came loose, I got the same thing.
    -Max.
    06 STU STI
    2006 STU Pro Solo Natl. Champ.
    www.zzyzxmotorsports.com
    Feb 2004
    any hose inperticualr? would this hose effect boost at all?
    Feb 2004
    did the CEL come back on after your cleared it?
    Jun 2005
    ct
    i reset the ecu...and i cleaned my MAF, and drivng tonight i noticed the engine temp was a little cooler than normal.
    its normally a little lower than the middle, but nothing it was just a little higer than the second line(first line being bottom)???????
    Jun 2005
    ct
    Quote Originally Posted by Mr_Ginzo
    no, i only drove like 30 miles
    Jun 2005
    ct
    okay so the cel came back on after 35 miles. same code.
    i dont know whats causing it....dirty injectors? something clogged? bad fuel?
    someone help
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Possible causes...
    1- Exhaust leak- check for leaks at all connections and for cracks or holes
    2- Air intake leak- same as above on air intake, intercooler hoses, etc
    3- Low fuel pressure- are you due for a fuel filter? Is the pump good?
    4- Coolant temp sensor
    5- Manifold absolute pressure(MAP) sensor
    6- Intake air temp sensor
    If its any of the last 4, I'd recommend taking it to a shop for a proper diag... Unless you have the proper equipment to test the sensors and fuel pressure
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
