Rust on hood
Results 1 to 9 of 9
This is a discussion on Rust on hood within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; quick question, will my hood rust? im quessing no cz aluminum. thakns...
    Jun 2004
    illinois
    Rust on hood
    Apr 2004
    Southeastern PA
    Mods & Pics
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    I wish I could slap you.
    Mar 2002
    Calmer than you are
    no
    go f*** yourself
    Apr 2006
    Buffalo, NY
    I know that it not nice to say. I should pull out my chemistry book from 4 years ago, but I will just give a short explanation. Aluminum doesnt rust like steel does, or at least at the same rate. Oxidation or combining with oxygen is what rusting is, also know as iron oxide. Corosion on aluminum is aluminum oxide, but happens at a much slower rate than steel. So to say that its not going to break down is not true, but the finish on aluminum lasts far longer. HOWEVER!!!! Comparable thickness of steel to aluminum, Al is a weaker metal, so it does dent easier.
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    Quote Originally Posted by afbluesv1k
    To add to this once a layer of oxidized Al is covering the top of the surface the oxidation is finished. It actually is stronger than pure Al if I remember my Chemistry correctly.
    It must be on the Subway diet. Did you name it Jared?
    Apr 2006
    Buffalo, NY
    Quote Originally Posted by tarbaj
    I think on a Rocwell hardness test it is but structurally I dont think it would be becuase its only on the surface.
    Jun 2004
    illinois
    Well, thanks for the replys. I asked that because i got a deep scratch and slight bend on my hood and dont want to spend 350 to fix it(quoted to fix by a bodyshop). One of my friends said it should be fine b/c its alum. so i figured i'd ask. Sorry if the question was unclear because i was in a hurry. The body shop said that even if i put touch up paint on it, it would still end up rusting b/c of the bend. Is this true?
    Mar 2002
    Calmer than you are
    Quote Originally Posted by aznwrx04
    it WOULD be true if the hood was steel, as most are. the body shop probably doesn't know the hood is aluminum, and I don't know if I'd want someone who doesn't know that to be working on my car...and if he does know its aluminum and thinks it will rust then run....run far far away.
    go f*** yourself
