Page 1 of 3 123 LastLast
Results 1 to 15 of 31
This is a discussion on ABS and CEL on and Speedometer is dead within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I was driving along 95 today and all of a sudden the car shuts off, then comes back on ...
    Dec 2005
    Delaware
    So I was driving along 95 today and all of a sudden the car shuts off, then comes back on (turbo timer kicked in i think) then stayed on, the speedometer was dead, i had a cel and the abs light was on. I also found out that when I hit 4 1/2 - 5k rpms the engine limits itself, like its redlining or something way too early. Idk whats wrong!!!
    Any ideas?
    Registered User Kush's Avatar
    Mar 2006
    Westchester, New York
    What mods do you have, and have you done any work to the car recently?
    New England F4
    www.OddTopic.net - my pet project, come say hello!
    '02 BUGEYE
    "One's level of fear is directly proportional to their preparedness for it's source"
    -Me
    DO A FRIGGIN SEARCH!!!
    Dec 2005
    Delaware
    None recently.
    Mods:
    Turbo XS BoV (I know I know, spare me)
    Greddy Turbo Timer
    Aftermarket cd player and subs
    thats it
    Mar 2006
    I really don't know, other than possibly your TT is screwing with the ECU in some way
    New England F4
    '02 BUGEYE
    -Me
    Registered User vypr2002's Avatar
    Jan 2006
    make sure your battery terminals are tight and not corroded.
    looks like you need to get the cels pulled before you do anything. also you are most likely in "limp mode" it restricts rpms and such to help prevent engine damage
    Dec 2005
    Delaware
    Found something somewhere where it said they had similar problems but it was the alternator ground
    Dec 2005
    Delaware
    Mechanic said he can't diagnose it, most likely the ecu he said. Wheres the best / cheapest place to get one, is there anything aftermarket that would give me any sort of gains?
    Mar 2002
    Calmer than you are
    you have to figure out what's wrong and fix your car before you worry about gains.
    sounds like you're in limp mode. pull the codes...that would be the place to start.
    go f*** yourself
    Mar 2006
    He can't diagnose it so he told you to get a new ECU?
    I'd find another mechanic, one who can diagnose the problem - it could be as simple as a corroded terminal somewhere. It's not hard to run diagnostic checks on the ECU with the right equipment, I'd definately have someone do that before you lay out a grand for a new computer you're not sure you actually need.
    New England F4
    '02 BUGEYE
    -Me
    Dec 2005
    Delaware
    Wheres the best place to get that done, I heard Autozone. True?
    Idk i was just hoping there would be a replacement unit that gives some gains while Im at it.
    Mar 2006
    I mean full diagnostic procedure, not just pulling CEL codes.
    New England F4
    '02 BUGEYE
    -Me
    Mar 2002
    Calmer than you are
    Quote Originally Posted by Silentdawn
    autozone or pep boys will pull your codes...MOST of them will do it for free...or so I hear, but I wouldn't trust them to work on my car. I have an accessport so I've never had to have someone else do it.
    go f*** yourself
    Dec 2005
    Delaware
    The only problem with a full diagnostic ATM, is money. I have had problems from the day I got this car, Bought it used, first day i would hit a slight bump in the road and it would squeak. been doing that ever since. had idling problems at one point, transmission problems. I hate used cars.
    Dec 2005
    Delaware
    CODE: P0502 - Speed sensor low input.
    After the code cleared, the speedometer started bouncing around. Any help?
    Mar 2002
    Calmer than you are
    so you have no mods except the turbo timer?
    sounds like for whatever reason you're not getting good signal. if possible, disconnect the turbo timer (you don't really need it anyway), check if maybe the TT wiring is shorting somewhere. you could be going into limp mode because the ECU isn't getting a good RPM reading. I'm sure someone else will have a few ideas.
    has the dash ever been out of the car? make sure the harnesses are secure.
    have you had the clutch replaced recently? maybe the speedo sensor got loose.
    go f*** yourself
