ABS and CEL on and Speedometer is dead - Page 2
Results 16 to 30 of 31
This is a discussion on ABS and CEL on and Speedometer is dead within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Yeah turbo timer is the only mod. I wont disconnect it for good, just have it as a security measure, ...
    Dec 2005
    Delaware
    Yeah turbo timer is the only mod. I wont disconnect it for good, just have it as a security measure, I know its not NEEDED, but in my case its wanted. The dash hasnt been off recently, well since I put the TT in..no, no new clutch recently.
    Dec 2005
    Delaware
    I never connected the speed sensor to the turbo timer btw...said it was optional in the manual.
    Mar 2002
    Calmer than you are
    well just unplug the TT and see if the problem goes away...that would at least isolate the problem. could be the RPM sensor grounding somewhere. (it does have an RPM sensor doesn't it?)
    go f*** yourself
  5. #19
    Dec 2005
    Delaware
    It has one yeah, but its just a taped off wire, ill go disconnect it in a few
  6. #20
    Mar 2002
    Calmer than you are
    Quote Originally Posted by Silentdawn
    If the problem doesn't go away from unplugging, follow the wire back as much as you can and look for a short somewhere. sounds like a short.
    go f*** yourself
  7. #21
    Dec 2005
    Delaware
    Which wire? The speed sensor from the TT is only an 3 inches long
  8. #22
    Mar 2002
    Calmer than you are
    speed sensor and RPM sensor...I don't know how long your wires are...never seen your setup. just trying to give you some ideas that might get you thinking in the right direction.
    go f*** yourself
  9. #23
    Dec 2005
    Delaware
    Ah also another issue I just found out. Headlights don't work. I just had one replaced at the dealership...could that have done anything? The blue high beam light doesn't come on either.
  10. #24
    There is an electrical fault somewhere. Consider what blarg said about tracing the TT wiring and also have a close look at the dash wiring -- I know you said it's not been off recently, but it has been off. Also, just for fun check that the main wires to the battery are secure, and that the main lead to the alternator is on tight too. Be careful.
    - Al Stewart
  11. #25
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    speed sensor could have failed or come disconnected
  12. #26
    Dec 2005
    Delaware
    I have no idea where the speed sensor is, but I disconnected the turbo timer completely and nothing. I even reset the ecu...removed the neg terminal and depressed the gas for a min. still the ABS light is on and no speedometer and no headlights.
  13. #27
    Dec 2005
    Delaware
    Any Ideas? I am fresh out.
  14. #28
    Dec 2005
    Delaware
    nothing?
  15. #29
    Dec 2005
    Delaware
    Why does the speedo jump around when Im driving, could this have anything to do with the BoV, HONESTLY!!! lol.
    I bought one of those warrantys from the car dealership that I got it from, I guess I'll just try to get that to help me out but I think that it is void even when i replace the cd player.
    The dealership wants 260 to replace the sensor... is that a decent price? Why is the ABS light on and why do the headlights not work? Is it all the same problem? Could the dealership have messed something up when they changed my headlight and gave me an oil change a couple days before this happened? The reason I'm thinking they might have done something is because I drove it all of 100 miles after that and this all started happening.
  16. #30
    Mar 2002
    Calmer than you are
    if you bought the extended warranty, it should cover electrical faults. sounds like you have something really messed up in there. let them fix it. if they figure out it was something you did, they'll charge you, if its a real honest-to-goodness electrical failure, they'll cover it.
    go f*** yourself
