That'll work, or you can use the frame just a little further towards the inside of the car.
tcc
This is a discussion on Question about jacking up my car for service - ASAP within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I drove the back up on ramps, and now I'm jacking up the front and putting jack stands under both ...
I drove the back up on ramps, and now I'm jacking up the front and putting jack stands under both sides.. I placed the jack stands dirrectly in front of where the factory jack goes. Is this a good place for them? I don't want to bend anything with it sitting up on the stands.
tcc
Step 2 Racing
http://www.step2racing.com
I lke to put them on the frame. I think the jacking points will work fine. But I must ask, if you are going to jack the car using the jack point, how are you going to exchange the stands for the jack if you'r eputting the stands in the sam place?
misterx
okay.. thanks
I'm changing the differential & trany(5mt) oil... do I just change the rear dif. or can I change the front dif. too?? I can't even find it![]()
not the jack points, right in front of them.. I'm sticking the jack stand dirrectly infront of the jack, then pulling the jack out and jacking up the other sideOriginally posted by MisterX
misterx
is the front diff lubricated by the transmission oil or what?
Yeah, the front and center diffs are integrated with the tranny.
1990 Alfa Romeo Spider Veloce
1993 Honda CBR600F2
2002 WRX SportWagon *sold*
there's lots of metal shavings on the tranny drain plug, is this normal? from break in?? I hope???
A Search revealed this. Please open it. It has a few pictures of the Jacking Points for our cars.
Jacking Points and Torque Specs?
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
I Drive Too Fast - Blog Where I Post All My Vids Check It Out!!!!
Bay Area Horsepower Fanatics Forums
http://forums.nasioc.com/forums/show...metal+shavingsOriginally posted by MainFrame
Seems pretty common.
Now that would be bad.![]()
Aloha, Richard...
Retired Moderator
TXS Stage 4 UTEC + TMIC + JoeP
12.75 @ 105.67mph - 1.74 60'
