Battery Keeps Dying? - Page 2
Results 16 to 30 of 33
This is a discussion on Battery Keeps Dying? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by iMP|2EZiONS Bump. So I'm heading home for the weekend and I'd like to resolve this problem for ...
    Mar 2002
    Calmer than you are
    Quote Originally Posted by iMP|2EZiONS
    Bump.
    So I'm heading home for the weekend and I'd like to resolve this problem for the summer. Is there a way to actually check if I wired into the constant or accessory? Or some way to figure out what I did exactly? Thanks guys!
    ok...how many wires on your gauges?
    2 for lights
    2 for power
    1 for sender?
    also, do you still have the stock battery?
    go f*** yourself
    Registered User iMP|2EZiONS's Avatar
    May 2004
    Colorado Springs/Boulder, Colorado
    Quote Originally Posted by blarg
    2 for lights
    2 for power
    1 for sender?
    Ok I have 3 gauges they all have black to ground, red to ignition (ACC switched power), yellow to illumination, and orange for a memory function (which my gauges don't have) therefore I taped it off. Nope the battery isn't stock.
    2005 CGM STi
    Mar 2002
    Calmer than you are
    ok, it sounds like you have your illumination hooked up right because the gauges flash when you unlock your car...
    when you turn off your car, do the gauges STOP working?
    go f*** yourself
  6. #19
    May 2004
    I'm almost positive that they stop working, I know the boost stops, I'm not too sure about the EGT and Oil Temp. I'm going to have my dad check and see if they do infact stop working.
    2005 CGM STi
  7. #20
    Mar 2002
    Calmer than you are
    well boost stops working because when the motor off, its at 0 PSI
    if your other gauges don't stop working when you shut off the car, then they're wired to constant power...
    go f*** yourself
  8. #21
    May 2004
    yeah I didn't think that'd help much. It was worth a try. I'll have an answer later today whether or not they shut off. Thanks for the help man, I appriciate it.
    2005 CGM STi
  9. #22
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    kind of a dumb question/thought, but on the column of your car by the steering wheel is that goofy parking light switch that does not turn on the interior dash lights, but does turn on the parking lights on the outside of the. if that was accidentally hit when you were cleaning or hooking things up, it will definitely drain your battery. We have at least one person a day call and say their battery is dead and they dont know why. most of the time is it because they somehow hit that little button there and didnt know it.
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
  10. #23
    May 2004
    Quote Originally Posted by GraysonSubaru
    Hahaha I actually did check to see if that was on. I remember reading about mysterious battery deaths and that was one of the biggest causes. So it was actually one of the first things I checked.
    2005 CGM STi
  11. #24
    Mar 2002
    Calmer than you are
    I'm sure you would have noticed by now if your parking lights are always on
    go f*** yourself
  12. #25
    Apr 2003
    I'm sort've having this problem, but it's not what I would consider typical.
    I did my guages a month ago, no problems.
    One morning my car just wouldn't turn over, sounded like your typical weak battery. Jumped it and all was fine. Fast forward to yesterday night and my roommate knocks on my door while I'm on the ****ter and tells me my alarm is going off. 10 secs later the alarm stops, I then press the disarm button and the parking lights just turn on for about 10 secs solid and that's it, no flicker or cabin light, or dash lights come on. my security light also flashed twice. And then it wouldn't crank. I then checked my battery and the water level was about mid-level. I'm not sure what it should be at, though. And I checked both times to make sure nothing was left on, and I'm positive I wired my gauges properly.
    So what could this be? Dead alternator, battery, or is the water level just low?
  13. #26
    Mar 2002
    Calmer than you are
    Quote Originally Posted by Chunks
    low battery could certainly cause relays to operate imporperly. I don't know what the water level SHOULD be...call the dealer and ask. I didn't realize the battery wasn't sealed until it started getting flaky and I just replaced it.
    go f*** yourself
  14. #27
    May 2004
    Ok I just checked my gauges and I'm pretty sure they're wired into the constant. The EGT and Oil Temp both still read numbers when the car is completely shut off. They don't fall down to zero. In the meantime I'm charging my battery so I don't have to jump it every damn time.
    2005 CGM STi
  15. #28
    Mar 2002
    Calmer than you are
    well, that would certainly drain your battery over time. you gotta re-wire those things. I tapped my cigarette lighter for my gauges with some vampire clips.
    go f*** yourself
  16. #29
    May 2004
    Ok I finally fixed it, I ended up tapping my hazard light switch with a vampire clip and it works great. I checked to make sure everything shut down properly, they illuminate whenever my headlights are on. So I think everythings fixed. Thanks for the help everyone. Blarg, thanks for helping me figure out what was wrong in the first place.
    2005 CGM STi
  17. #30
    Registered User section9's Avatar
    Jun 2005
    AK49
    If that doesn't work, it could be that your battery wasn't properly prepared in the first place. Batteries are shipped dry to the store, both conventional and maintenance free ones. When a customer buys one, the shop is supposed to fill it up with the correct electrolytes, let it settle for an hour, refill to the correct level, then charge it up. Battery life greatly depends on how well this is done. I've had my OEM battery for almost 100k miles now.
    Batmobile: 2002 WRX wagon RIP
