Results 1 to 8 of 8
This is a discussion on Knock Knock Knock.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am having a weird knocking sound when I let off the gas and it goes back to idle. I ...
    Registered User scooby-x's Avatar
    Oct 2004
    State of depression
    I am having a weird knocking sound when I let off the gas and it goes back to idle. I thought it might be rocker knock, but when I took it to the dealer the service manager and I both noticed that it is coming from behind the engine... could be the turbo or something. Now could this be the wastegate, or is it a busted fin, or worse off is there mad shaft play in the turbine? And might this be fixable? Thanks
    Oh and it will do it at idle after a spirited run....
    Basically I am wondering if anyone else has had this sound pop up on them. It sounds just like a rocker knocking....
    04 Java Black Pearl - Sleek Eye
    All you see is my license plate... SCOOBY-X
    Quote Originally Posted by GOD The Almighty
    Patrick, you are a complete accident
    Oct 2004
    State of depression
    come on someone has to know...
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    Someone on here probably does know, but they may not have been on between 5 and 6:30 tonight. Patience.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Oct 2004
    State of depression
    bump the question...
    Sep 2005
    same knocking sound.
    I have the same problem. What was the cause/fix. Thanks.
    Registered User Station's Avatar
    Feb 2007
    Evansville, WI
    I also have noticed this knock at idle on my 05 WRX.
    I dont notice pings or knocks while accelerating thru any gear, just while at idle.
    It happens when I start the car cold and when its warm after my 30+ mile daily commute.
    Any thoughts?
    EDIT- Oops, found the answer elsewhere, Search button is my friend. Apperently this is a known issue and has been answered in other posts.
    Registered User CAPETANN8's Avatar
    Aug 2005
    maryland
    if its cold and you start up boxer engines are very loud, knock and make noises, just let it warm up.......
    HOWEVER
    if you drive the car around and the car is at OPERATING temperature, and your at idle and it still sounds a little knocky, i personally noticed if the engine is not completely full with oil (4.8 quarts) (i normally put in 5).....it will knock even at just a half a quart low the engine is loud.......i notice about every 1500 miles i will be a little oil maybe half quart sometimes more, especially when i use a thinner oil 5w 30 mobil 1, in the summer i put 15w 50 mobil 1, doesnt burn at all.......check your oil, if its more than that, i dont know what the problem, but boxer engines crave perfect oil level
    Registered User gda03subaru's Avatar
    Mar 2007
    Austin, Texas
    i have this same noise coming from the top of the block on the back side of the motor. at first i though it was bad gas, so i drove it completely out and went to a different station and got premium, still there. so i changed the plugs, still there. If the car is at idle and you tap the gas a couple of times it goes clack or knock then goes away does fine with no noise under acceleration but as soon as you let of the gas you hear it again breifly just started a couple of days ago very disturbing sound anyone know
    HAVE YOU SEEN ME?
