Help: 2002 Wrx Losing Boost
Results 1 to 4 of 4
This is a discussion on Help: 2002 Wrx Losing Boost within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 2002 Wrx loses boost from 5000 rpms to 7000 rpms(redline). If anybody has an idea of what the problem ...
    Mar 2006
    My 2002 Wrx loses boost from 5000 rpms to 7000 rpms(redline). If anybody has an idea of what the problem might be, please respond. I'm losing a good bit of horsepower. It goes from .8 or .9 down to .5 during that rpm range. Any help would be appreciated. Thanks.
    Administrator
    May 2003
    Quote Originally Posted by 2002 Wrx
    That's perfectly normal. The stock turbo runs out of breath in the upper rpm range.
    Mar 2006
    Are you sure? I thought the peak horsepower(227) was at 6,000 rpms. I can't be still hitting that if I lose power starting at 5,000 rpms. Can I?
    Moderator
    Jul 2003
    Maryland
    Um.....there is more to making power in a car then full boost. The turbo will taper off as you get higher in the rev range. Doesnt mean the car is making less power.
