Car steers harder to the right
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
This is a discussion on Car steers harder to the right within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ever since I've had this car, I've always felt like the steering has been off. I've also had some drifting ...
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Ever since I've had this car, I've always felt like the steering has been off. I've also had some drifting issues corrected by the dealership. The first reported issue, under 4k miles, was fixed with an alignment. The 2nd issue was a tire pressure issue that made me feel idiotic for taking the car into the dealership, around 10k miles. I 'thought' I had checked the tire PSI. Even when the issues were 'fixed,' something still always felt off with the wheel and I feel like I make constant adjustments when I drive.
    It wasn't until over the winter time that I realized exactly what the car is doing. When I turn the wheel to the right, while moving, the wheel is noticeably more resistant when I turn to the left. This is especially noticeable during long sweeping daily driving turns. It really feels like the car doesn't want to turn right, but it will turn left very easily. This feel is slightly more heightened now with my RCE yellow springs and 265 tires.
    I'd love to take it into Subaru, but I have a strong feeling they're going to tell me two things:
    1) We don't notice it. (the usual answer)
    2) It's because of your aftermarket spring/tire/wheel setup (which has been on for less than a month)
    I held out on taking the car to the dealership again prior to the spring installation, because I thought a professional alignment from a good alignment shop would fix it, but it did not. I told the shop about the issue and they said they couldn't see anything wrong with the suspension, but I'm not too sure how hard they looked. I'm looking for anyone who has any ideas of what might be causing this problem or how to go about getting this taken care of? I am aware that fixing this may come out of my pocket, due to the aforementioned mods.
    The only side note is that at about 1500 miles I rolled up on a steep 8" curb and the car slammed down pretty hard, causing no visible damage. However, I believe I was making these adjustments before this small incident. This issue is one of the reasons I believe I really haven't become attached to this car.
    lit fam XJman's Avatar
    Feb 2015
    At work
    Does it change at all when you are on a different part of the road? Many roads are not flat but arc shaped to shed water to the outside of the road. Who did you have do the alignment? I had mine done at a performance shop and it's straight as an arrow as long as I'm on something flat.
    If something was bent it would likely cause the same issue left or right.
    All? NO ALL!
    Oct 2015
    MD
    Nothing helpful to contribute other than a bump, but I've notice something similar in my 2016 WRX. I don't necessarily notice it being more difficult to turn left or right, but I do notice that I constantly have to correct the heading of the car. Most of the time it tends to pull towards the middle of the road (left) which is the opposite of the theory by XJman.
    Was going to get an alignment done. Probably still will, but disappointing to read that may not solve the problem.
    Anyway, good luck!
    Aug 2012
    Tucson, AZ
    I remember you talking about this a while back. Pretty sure I thought it could be because of the crown on the roads but it was more severe pulling than that?
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Aug 2008
    Even when the crown of the roads are sloping to the right it still has more resistance when turning right. Also, the car drives completely straight, but I can feel more tension when I pull the steering wheel to the right, making natural crown of the road corrections more noticeable.
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    I might put the car up on blocks/jack stands and try turning the wheel each way stationary to see if it feels different. To me that would indicate something in the hydraulic PS unit..........
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Quote Originally Posted by rqjoe View Post
    I might put the car up on blocks/jack stands and try turning the wheel each way stationary to see if it feels different. To me that would indicate something in the electric PS unit..........
    2015+ STI retains the hydraulic power steering system of the previous generation, unlike the 2015+ WRX's new electronic power steering unit.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Aug 2012
    Tucson, AZ
    I can only guess. This has been an issue for some time with it at this point hasn't it?
    I'm wondering if the P/S system is blocked somewhere
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
    Aug 2008
    I put the car on level ground the other day and turned the wheel lock to lock. I felt no distinct difference in resistance from right to left. No popping, binding, etc. I feel that the issue is much more prominent during any kind of acceleration. The issue seems to go away when my foot is off of the gas pedal.
    Feb 2015
    At work
    I'm leaning more and more to something odd in a cv joint or the lsd
    All? NO ALL!
    Sep 2013
    Buckeye State
    I think this is the design of the car. I've noticed that when I'm taking a slow sweeping turn in either direction that when I am accelerating, no matter the severity, the car jolts a little towards steering in more severly without my changing the position of the steering wheel. Similarly, when I'm decelerating through any sweeping turn and give the car a little gas it seems to pull outside under acceleration without having moved the position of the steering wheel. It's kinda hard to explain, but my only theory is that this is just the the front wheels naturally trying to straighten out when under power. Is this similar to what you are experiencing?
    Billy
    Stink-Eye Mob #696
    Facebook
    Feb 2015
    Ohio
    I think he is saying it is doing something different turning right vs. left. That would indicate a problem. OP does it do this in all 3 VDC modes (normal, traction, off)?? I'd see if that made any difference.
    Aug 2008
    ***Update***
    I took the car to the dealership last week. The relief was when the tech felt the problem. The dealership gave me another alignment, but I had to pay for it this time. Despite just recently having it aligned, it was pretty far out of spec. They gave me the car back after keeping it half the day, but the wheel is still more resistant when turning to the right. I'm going to make another appointment.
    Feb 2015
    At work
    I'm wondering if something is wonky in the power steering.
    All? NO ALL!
    Aug 2008
    The steering has never felt right on this car. I wouldn't be surprised if it's a steering rack issue.
