2011 Intercooler boot clamp size
Results 1 to 8 of 8
This is a discussion on 2011 Intercooler boot clamp size within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I think I've narrowed down my boost leak to my intercooler boot. I was wondering what size t-bolt clamp they ...
    lit fam XJman's Avatar
    Feb 2015
    At work
    I think I've narrowed down my boost leak to my intercooler boot. I was wondering what size t-bolt clamp they take. I found one source that said 2.75 but I can only find 2.5 and 3. Can anyone who has replaced these to fix a leak there comment on what size clamp they used.
    Mar 2016
    https://www.amazon.com/Mishimoto-MMC.../dp/B004MEGXLU
    I think summit racing also has some in stock as well
    Feb 2015
    At work
    So it is a 2.75. man that sucks I'd prefer to find them local.
    Sent from my Nexus 6 using Tapatalk
    All? NO ALL!
    Mar 2016
    I tried finding them locally but couldn't. I ended up just taking off the boots from both ends and reusing the worm clamps.
    Feb 2015
    At work
    Will they cinch down tight enough?
    All? NO ALL!
    Mar 2016
    Sure will. The leak is just due to those stupid grommets subaru decided to use. Take a mental picture as to how the hose was before you remove it. I spent more time trying to get the right angle to put the hose on than I did removing the damn thing
    Feb 2015
    At work
    I figure I'll update this saga. So here is the deal. Everything was coming off nice and easy. I used a 12mm bit for my screw driver for all the bolts, all was good, all was well. Then the back bolt on my turbo said snap. I know I've got some ham hands but I have a feeling that someone has been here before because this boy came off with the twist of a wrist. I'm also assuming this is part of my boost leak issue as when the other bolt came loose the top mount had a slight wiggle to it.
    Oh well.
    All? NO ALL!
    Feb 2015
    At work
    Got up today and drilled out the old bolt and did some thread repair. It isn't perfect by any means but it is beyond good enough for its purpose.
    All? NO ALL!
