The Noise Persists
Results 1 to 3 of 3
This is a discussion on The Noise Persists within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I've had a weird noise coming from my front driver side wheel for a while now. It started as ...
    Registered User mustwarnorcas's Avatar
    Sep 2015
    HB, CA
    The Noise Persists
    So I've had a weird noise coming from my front driver side wheel for a while now. It started as a high pitched distinct squeak which was oscillating and relative to speed and somewhat relevant to wheel position. Initially I thought it was brakes so I now the car has new rotors, pads, and different front calipers. After that install, the problem was not resolved and continued to squeak. My next thought was the cv joint. So, I installed a new cv half shaft last weekend and noticed a change. Now, the squeak mainly occurs when the wheel is turned slightly or coming to a stop and the squeak has changed to a low creak. When driving straight the car does not make the noise. I don't believe it's the wheel bearing because it is not a constant grinding/whirring noise. My other hypothesis is that it is the tie rod end, which could possibly provide an explanation for the change in tone of the sound since the tie rod end was moved and constantly worked during the cv half shaft job. I'm confused here and any input would be appreciated.
    "If the power increases, then I have to spend more money on gas" - Takumi Fujiwara
    Build: http://www.clubwrx.net/forums/builds...eye-wagon.html
    Water.....sometimes waves rqjoe's Avatar
    Feb 2015
    Ohio
    Your name makes me think of the Star Trek movie where they haul the whales to talk with the alien ship.
    I have had squeak/squeal on 2 different cars; both times it was a small steel bracket that had somehow gotten bent so it touched the rotor. It squeeked variably depending on speed and wheel position.
    Sep 2015
    HB, CA
    Lol never heard of that Star Trek movie before but I'll take another look at the dust shield and around the back of the rotor to look for any abnormalities.
