Low Oil Pressure then Check Engine Light - 2008 STI
Results 1 to 10 of 10
This is a discussion on Low Oil Pressure then Check Engine Light - 2008 STI within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; On Friday night I was driving to dinner and about 4 miles from my destination my Low Oil Pressure light ...
    May 2016
    On Friday night I was driving to dinner and about 4 miles from my destination my Low Oil Pressure light would occasionally blink on for a second. I thought I would just get to where I was going then try and solve the problem. I drove the rest of the way there and by the time I ate dinner I completely forgot about the issue. The drive home was about 8 miles (freeway driving) and probably 2-3 miles from home my Check Engine Light came on and my Cruise Control light started flashing. I drove the rest of the way home and parked it for the night. The next day I checked my oil and it was VERY low so I walked to the gas station and ended up adding 3 quarts of oil. Now my Check Engine Light is still on and the Cruise Control light is still flashing and I don't know how to turn it off. The car sounds normal, and while driving it feels like it is in the "Intelligent" mode. My question is, what am I supposed to do now? Do I just keep driving with the CEL on, or should I disconnect the battery and see if it goes away? Should I be trying to get to a dealership? Is the engine ruined and I just don't know it yet?
    Read and post the error code.
    Les jeux sont faits.
    May 2016
    When I turn the key to accessory on position and hit the trip button 4 times, turn the headlights on, 4 times, headlights off, 4 times, headlights on, button 4 times I get the following codes.
    P0024
    P0014
  5. #4
    Those are both camshaft and timing error codes and could be a secondary result of the low oil level.
    Where did the 3 qts of oil go? Is there a leak? Do you check oil routinely? Is it full now?
  6. #5
    May 2016
    It is full now. I park on the street and I have never noticed oil spots but I also have not been on the lookout for them. I had my oil change with synthetic oil about 3000 miles ago, but I do not regularly check the oil. I have had this car just over a year and I have not had any issues like this before.
  7. #6
    lit fam XJman's Avatar
    Feb 2015
    At work
    First you need to find where 3 quarts of oil went. That is 3/4 your oil volume. Even if you fix your cam sensor issues if you are blowing through 3 quarts of oil in a week or 2 you've got a major problem
    Sent from my Nexus 6 using Tapatalk
  8. #7
    See if there is an oil leak. If you cannot do it, take it to a mechanic. The owner's manual says to check the oil every time you refuel. I check every fortnight or so, still more frequently than many people but not as frequently as I should.
    If the cause of the CEL is gone then the light should go off on its own after several duty cycles. I have no way of knowing if your motor is actually OK though, especially not remotely.
  9. #8
    May 2016
    Does this sound like the right course of action? Check my oil every morning before work to see if it is draining rapidly, and bring a piece of cardboard to put under my car when I park at work to look for oil spots. If the CEL is not gone by the end of the week schedule a time to go into the dealership. If I find an oil leak schedule a time to go into the dealership. If over the next week the CEL goes away and I find no oil leak, then start checking the oil every time I fill up and look for any noticeable changes.
    The other option is just to take it to the dealership ASAP.
  10. #9
    Feb 2015
    At work
    I'm thinking the oil is going out the exhaust. Do you still have coolant?
  11. #10
    May 2016
    Yes. The coolant level is about half way between full and low.
