Issue with 02' WRX - WOT 4-4500 RPM - Shutter/Hesitation
Results 1 to 5 of 5
This is a discussion on Issue with 02' WRX - WOT 4-4500 RPM - Shutter/Hesitation within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey Guys, Having an issue with my 2002 WRX. When I'm pushing the car at WOT or close to WOT ...
    Apr 2016
    Hey Guys,
    When I'm pushing the car at WOT or close to WOT - it stutters, jerks, hesitates and has a loss of power at around the 4500RPM mark.
    I've changed spark plugs and it did make a difference but the issue is still there.
    I'm considering resetting the ECU before trying anything else but I'm a bit hesitant about the ECU having to relearn.
    Here is a bit
    of background on the car and what mods I'm running etc.
    * Subaru factory forged EJ207 semi-closed block (<7000KM)
    * Tuned to E85 on 25PSI - Very safe tune.
    * 11mm oil pump, new water pump, new radiator, new timing belt kit with new pulleys, idlers and tensioner installed at same time as semi closed block.
    * TD05-20g Billet Wheel Turbo
    * Full 3 Inch Exhaust
    * GFB Electronic 3 Port Boost Controller W/ Overboost Safety Function - 6 boost settings - I generally run it on the 22PSI setting.
    * Cold Air Intake (also tuned for it)
    * STi Intercooler
    * Silicon Intake, Silicon Y Pipe,
    * DW300 Fuel Pump
    * ID1000 Injectors.
    * New A/C compressor and hoses (regassed)
    Registered User mustwarnorcas's Avatar
    Sep 2015
    HB, CA
    Can you read the IDCs? Any intake/vacuum leaks?
    "If the power increases, then I have to spend more money on gas" - Takumi Fujiwara
    Build: http://www.clubwrx.net/forums/builds...eye-wagon.html
    Apr 2016
    Quote Originally Posted by mustwarnorcas View Post
    No way for me to read the IDC's.
    No visible leaks that I can see.
    Sep 2015
    HB, CA
    I doubt you'd be maxing out ID1000s but just a good place to start, any lights or cels when you get the hesitation?
    Apr 2016
    What's the best way to check the injectors? Or should I just get a mechanic to?
    No lights or CEL's when the issue occurs, I am using an 06' STi dash though so if that wasn't wired correctly CEL might not show at all?
