Ex temp.
Results 1 to 9 of 9
This is a discussion on Ex temp. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I have a 04 wrx what should I be running for ex temp?...
    Jan 2016
    Ex temp.
            MainFrame's Avatar
    Austin, TX
    Depends on where you put the sensor.. in general, you don't really want to go much over 1650ºF during prolonged WOT. That is, if you have the sensor on the #4 primary within an inch or two from the head. The only thing you really need exhaust temperature readings for is to dial in the timing on an aggressive tune.
    Jan 2016
    Okay. Well it just will climb up to 1600 when I'm getting on it
    Jan 2016
    And I was scared that it was to hot for the car. Also I have subs in my car and when they are on the gauge moves around alot to the beat of the music. Guessing the gauge is bad or wired up wrong?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Where is the sensor?
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2016
    You know I have no idea.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Dillon.merren96 View Post
    If you didn't install the sensor, it's in the UP and can't be used for EGT diagnosis.
    Facebook me here
    Jan 2016
    I'm not sure where it is. Is it hard to find?
            MainFrame's Avatar
    Austin, TX
    1600 degrees in the uppipe could be over 1800 degrees at the heads, which is hot enough to melt stuff.
    The gauge moving with the beat of the music means it's not properly grounded.. if the gauge is grounded badly I wouldn't trust any of its readings.
